Do Sills Need To Be Seam Welded At Top And Bottom Or Can They Be Tacke
8 replies to this topic
#1 The Mini
The Mini
  • 16 posts
Posted 13 March 2011 - 03:54 PM
~~~~~Please delete this text before posting the topic~~~~~~
Please give your topic a title that quickly describes your problem. Just putting 'Help my Mini doesn't work' is useless to anyone trying to help.
Model:
Year:
Any non-standard parts that might be involved with the problem?
#2 wardyxxx
wardyxxx
  • 1,327 posts
  • Local Club: Leicester Mini Club
Posted 13 March 2011 - 04:06 PM
You need to type your problem with a description in the big white box.
Not the title bar.
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,076 posts
  • Name: Neil
Posted 13 March 2011 - 05:48 PM
You can if you want to seam weld the sills but spot welding them or plug welding at approx 1" apart is fine. i seam weld at each end where the sill attaches to the rear heelboard and the front inner wing lip.
#4 The Mini
The Mini
  • 16 posts
Posted 13 March 2011 - 07:24 PM
Many thanks think that's what im gonna do iv a five
Litre tin of tetrosol undercoat so iv sloshed lots of that
On then spot welded ever inch or so can't belive how bad
The old ones were. When I stripped old ones off on the
Back there was a production sticker dated 2004 so they
Ain't lasted very well lol
#5 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,146 posts
  • Name: Sean
Posted 13 March 2011 - 07:28 PM
I tend to seam weld them, its easier and quicker!!
I also feel a little bit safer knowing that they've been seamed as well.
Its not original but to be honest I usually don't care!!
#6 The Mini
The Mini
  • 16 posts
Posted 14 March 2011 - 07:11 PM
I checked this just to be sure today and the nasty
Mot man says " it's a replacement part
Not a original one and it was seam welded
When it started out in life so needs to be seam welded
Again" so if this is then case am I right in thinking as I cut a
Rotten panel out It should be seam welded it it was to start
But things like A panels and wings can be re tacked back on
#7 feybrand
feybrand
  • 1,247 posts
Posted 14 March 2011 - 07:36 PM
sills arent seam welded when they come out of the factory their spot welded
#8 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 14 March 2011 - 07:39 PM
Only if you replace like for like can the panel be attached using the same method the original was attached...
If you use wide sills or oversills, they MUST be seam welded.
#9 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 14 March 2011 - 07:40 PM
there is a place for seam welding and a place for spot of plug welding, orginal sills should be spot welded, it has more strength than seam welding in this case, the rule is orginal panel lines spot/plug weld. repair seam weld. butin all cases of welding good penitration is important.
