Hub Nut (castle Nut)
Posted 17 March 2011 - 08:41 AM
Anyone know the size of the front hub nut (castle nut with single split pin)
I know its either a 33mm or 34mm but not sure and need to buy the socket today
Many thanks in advance
Posted 17 March 2011 - 08:56 AM
Its neither of those because its an imperial size, 1 5/16"Hello, only simple question
Posted 17 March 2011 - 09:13 AM
Posted 17 March 2011 - 10:04 AM
Which model is the 34mm on? i thought that was just a minispares thing, using imperial threadsTwo nuts have been used on the production line, and both are still available from suppliers. Both are interchangeable. One is 1 5/16" and the other is 34mm. If you are going to be working on a lot of Minis you should have both sockets, if you have only your car to worry about find out which socket you need. The 1 5/6" is used in many other places on the car though, which the 34mm isn't.
Posted 17 March 2011 - 10:57 AM
I dont think it was a particuler model as such it just seemed that later on they started usin the 34mm nuts as poeple at home had metric socket sets and it was easier for them.
As Dan has said I would check what nuts you have and then buy the correct socket. I converted all mine to 1 5/16ths because again the socket for it is used in other places and I therefore only needed to carry about the one socket!
Posted 17 March 2011 - 11:28 AM
Saying that, I've been stripping parts off the engine for removal and only needed to use a few Imperial sockets
Posted 17 March 2011 - 12:42 PM
I've used cutlery to undo screws before now, but I'd be shocked at anyone advising me to do so
Charlie T and Dan are simply telling you the correct size tools for the job, if you choose to use something different and you hurt yourself, your car or others then you cannot blame advice given on the forum.
Edited by GraemeC, 17 March 2011 - 12:43 PM.
Posted 17 March 2011 - 02:42 PM
Posted 17 March 2011 - 04:55 PM
Posted 18 March 2011 - 12:52 AM
Posted 18 March 2011 - 06:27 AM
Posted 18 March 2011 - 07:48 AM
I had to cut a 1 5/16 off of a CV and the repacement nut from Minispares was 34mm.
Presumably because you ordered the 34mm or didn't specify what you wanted - they sell both.
I would suspect if you just ask for a hub nut you would be supplied the cheaper, metric one:
http://www.minispare...=...6075&title=
http://www.minispare...=...2843&title=
