I get a loud scream from clutch when i set off in 1st, was told it was the clutch release bearing, so i changed that, but im still getting the noise.
What else could it be? Worn clutch arm? Worn flywheel housing cover?
Car is a 89 998 with 106k on the clock
Thanks Iain.
Screaming From Clutch When Setting Off
Iain L
, Mar 18 2011 06:43 PM
4 replies to this topic
Posted 18 March 2011 - 06:43 PM
Posted 18 March 2011 - 07:57 PM
Just a thought but could it be your fan belt? I had similar symptoms and that is all it was.
Posted 18 March 2011 - 09:16 PM
Definatley coming from clutch, its a deeper noise than a slipping fan belt
Posted 19 March 2011 - 03:04 PM
Bump. I am interested in the subject. My Cooper SPI makes sometimes a similar noise. It depends on RPM'S and the clutch pedal being half way out. I was thinking release bearing too.
Posted 19 March 2011 - 05:04 PM
I got told it was the release bearing so went ahead an changed that but still getting noise. Like you say though it can do it an then not do it depending on revs an clutch position, sounds bloody awful when it does it.
