Mini Keeps Loosing Power When Driving
7 replies to this topic
#1 freshairmini
freshairmini
  • 1,718 posts
Posted 24 March 2011 - 09:36 AM
Hi,
Ive got a 1990 1275cc cooper.
I was testing out my new suspension yesterday and took it for a drive to see how well it drove. I was driving along fine for the first few minutes of the journey, then when it can to a slight hill I completely lost engine power. I tried revving it a bit and nothing, just completely lost power. So I got out checked in the engine bay, the fat cable to the center of the coil looked a bit loose to I pushed that back on and started it up again and it was fine.
Then on the way back home it did it for a second time! just lost power and wouldn't accelerate, I checked the fat cable from the coil but that wasn't loose so now I'm not sure what caused it.
It has been sitting not driven for about two weeks while I fitted the suspension and was waiting to get it set up.
So can anyone shed some light on this??
Thanks!
#2 bmcecosse
bmcecosse
  • 9,699 posts
Posted 24 March 2011 - 09:56 AM
Fuel starvation? Carb piston sticking?
#3 freshairmini
freshairmini
  • 1,718 posts
Posted 24 March 2011 - 09:59 AM
Yeah I did think of that, But it was fine like a week or so ago, and I haven't touched the carb, so not quite sure.
What can cause those problems?
Edited by freshairmini, 24 March 2011 - 10:00 AM.
#4 The Goot
The Goot
  • 18 posts
  • Local Club: Mini WIPS
Posted 24 March 2011 - 10:22 AM
Same thing, sort of, happened to me a few years back. Lost all power in a round about. Long story short...the ignition coil went out. Simply replaced it after checking everything else and started like a champ.
The Goot
#5 freshairmini
freshairmini
  • 1,718 posts
Posted 24 March 2011 - 10:53 AM
Is there any tests you can do with a multi meter to check if it needs replacing for definite?
#6 The Goot
The Goot
  • 18 posts
Posted 24 March 2011 - 10:58 AM
you could verify if it is supplying the right amount of power required with a multimeter. I had an extra one and tried it, it worked so that's how i sorted mine out.
#7 freshairmini
freshairmini
  • 1,718 posts
Posted 24 March 2011 - 11:03 AM
do you know what the right amount of power it should be supplying is?
#8 freshairmini
freshairmini
  • 1,718 posts
Posted 24 March 2011 - 03:11 PM
On another note, Just had a call from by brother at home saying that there is coolant leaking from the cylinder head around the gasket area, Could it be possible that a loss of power could be from a blown head gasket??
