Fly wheels
Posted 06 January 2006 - 02:52 PM
Just looking around as im bored at the mo and while looking for things to get for Bertie found this
http://www.minispare....aspx?pid=35440
Why isnt it recomended for road use? Which one is best to get? The car is only a weekend car (if its lucky) and im not sure if my car has a verto or not (dont even know what that is!!!)
Johnny
Posted 06 January 2006 - 02:58 PM
OMG that is badly worded, but I know what I mean!
Posted 06 January 2006 - 02:59 PM
Posted 06 January 2006 - 03:00 PM
Posted 06 January 2006 - 03:11 PM
Heres a pic
http://img.photobuck.../vertoornot.jpg
Does this help???
Also, is it worth changing? Will you notice the difference and is it hard to fit?
Thanks again
Johnny
Posted 06 January 2006 - 03:14 PM
that's a verto clutch!
Posted 06 January 2006 - 03:16 PM
Posted 06 January 2006 - 03:29 PM
Hey Alanjohnny,
Does that mean the wheel if ound at the start of the thread is no good then? Can i get a wicked one for a verto?
Johnny
Posted 06 January 2006 - 04:19 PM
Vertos can be lightened, but not to the same extent as diaphram, if you do want to go that way, I can probably get one done for about 50, which would be a lightened flywheel, pressure plate and the faces skimmed ready for a new clutch plate...
PM me or MRA-Minis if interested.
If you do decide to change to diaphram, then you will also want a lightened back plate http://www.minispare....aspx?pid=32797 and a decent clutch plate and diaphram.. don't expect much change from 250
Posted 06 January 2006 - 04:37 PM
With all that said then, is it going to be worth doing?? My missus hates me having days off work because i get bored and spend too much!! (you will see it all unfold tonight Alan aka mad jonesy)!!!!!!!!
Whats worth getting done instead then?
Johnny
Posted 06 January 2006 - 04:50 PM
Posted 06 January 2006 - 07:57 PM
if you are going to buy a new one buy a lightwieght steel one and a steel backplate, not the ultra light one. Lightened standard flys can in some instances explode if not done right or lightened to far. Safer bet is the steel one
Posted 06 January 2006 - 09:15 PM
Posted 06 January 2006 - 09:16 PM
The real advantage in a lightened flywheel isn't a higher top end, it's greater acceleration. By taking mass off the flywheel you allow the engine to rev up faster which translates to better acceleration times for the car as a whole. There are formulas to apply but I've routinely heard round numbers bantered about implying that 1 pound off the flywheel is like taking 100 pounds off the car.
OK side bar:
This is a question for you people who know the old cars and in particular the older BMC variants like the MG-1100. CAN I use a flywheel from a 1098 transverse engine on my 1275? Are the crank tapers the same? There's a NOS flywheel on eBay at a good price but I can't match the BMC/MOWOG number the seller gives for the assembly. He says that it's a flywheel for an MG-1100. Please let me know if I can use a 1098 flywheel on my 1275. Thanks.
EDIT: About that verto/pre-verto question above... I've been told that the two are not interchangeable but I don't understand why. I know that the pre-engaged starter doesn't require that the ring gear teeth be chamfered. So this would prohibit you from using a Bendix starter on a verto flywheel. However, I don't know why you couldn't go the other way. I would think you could use the pre-verto flywheel with a pre-engaged starter... but I thought someone had told me not to. I have an Australian acquaintance who runs a pre-engaged starter from a Holden on his pre-verto Mini... so there's at least some anecdotal evidence that you can do it in some circumstances.
Edited by dklawson, 06 January 2006 - 09:21 PM.
