Spacer-external Door Hinges-angled 14a7387
Posted 30 March 2011 - 03:12 PM
I need some of these spacers to fit my doors mk1
http://www.somerford....roducts_id=310
Somerfords are out of stock, cant see anyone else who sells them, so I thought I will just make some.
Could someone please let me know the size of them and the angle.
Thanks Dave
Posted 30 March 2011 - 03:16 PM
Posted 30 March 2011 - 04:35 PM
Link's broken
lets try again
http://www.somerford...products_id=310
Edited by LOT977F, 30 March 2011 - 04:35 PM.
Posted 30 March 2011 - 08:29 PM
Posted 01 April 2011 - 04:30 PM
Take a length of 1/2" diameter aluminum rod. Drill a 1/4" hole through the center. Cut a "wedge" off the rod by angling the hacksaw blade at about 15-20 degrees. That gives you one washer. Make your second cut at 90 degrees and you will get a second washer. Repeat until you get all you need. Use a coarse file to remove burs and saw marks from the angled surface.
THANKS
