No Lights
12 replies to this topic
#1 miniallsort
miniallsort
  • 4,723 posts
Posted 01 April 2011 - 07:54 PM
~~~~~Please delete this text before posting the topic~~~~~~
Please give your topic a title that quickly describes your problem. Just putting 'Help my Mini doesn't work' is useless to anyone trying to help.
Model: austin mini mayfair
Year:1986
Description of problem (please be as in depth as possible): alright chaps got a few problems head lights dimp or main dont worrk on my mini replaced all the fueses checked wires ect got a brand new battery also the right side light doesnt work and when you turn the headlighht switch on the rear lights dont come on or number plate light
please help me !!!
:thumbsup:
Any non-standard parts that might be involved with the problem?
#2 Sagey
Sagey
  • 487 posts
  • Local Club: The mini forum
Posted 01 April 2011 - 08:05 PM
dodgey fusebox? have you power from both sides of fuse?
#3 bmcecosse
bmcecosse
  • 9,699 posts
Posted 01 April 2011 - 08:07 PM
Perhaps blown fuse (despite having been replaced) or bad connection in the sidelight circuit - and/or bad earths where they are 'dimp' [sic] ??
Edited by bmcecosse, 01 April 2011 - 08:12 PM.
#4 miniallsort
miniallsort
  • 4,723 posts
Posted 02 April 2011 - 09:22 AM
Hi just pulled the light switch out and found that there is no spade connectors. Attched to the switch hopeful this will fix the problem I've also found that my washer jest don't work and rear tail lights any advice would be great
#5 Blackfear
Blackfear
  • 66 posts
  • Local Club: British mini club
Posted 02 April 2011 - 11:03 AM
if you find out how the tail lights dont work or jet washers, Give me a pm because i got the same problem mate.
#6 miniallsort
miniallsort
  • 4,723 posts
Posted 02 April 2011 - 06:41 PM
alright guys found out why the right had side repeater wasn't working one of the wires had snagged off so gott replace that. does anyone no where the wires connect to from the headlights grill / slam panel area haven't a clue where they go
#7 miniallsort
miniallsort
  • 4,723 posts
Posted 02 April 2011 - 10:19 PM
bump any help with his question
#8 leroy26
leroy26
  • 2,239 posts
  • Local Club: minisunleashed.com
Posted 03 April 2011 - 05:33 AM
theres loads of bullet connectors by the slam panel, take ya grill off and youll see em! got to do mine today, clean them all!
they go thru your inner wing up to the lights and from the drivers light up to thru the bulkhead to the switch
Edited by leroy26, 03 April 2011 - 05:35 AM.
#9 miniallsort
miniallsort
  • 4,723 posts
Posted 03 April 2011 - 11:44 AM
ive just had a new front end welded on and the guy who did the welding just pulled all the bullet connectors off and now i dont know where they go
#10 leroy26
leroy26
  • 2,239 posts
Posted 03 April 2011 - 11:51 AM
basicly match all your colours up, red to red blue/white to blue/white etc you should have two wires going in to the connector from the drivers side and one coming out.
#11 miniallsort
miniallsort
  • 4,723 posts
Posted 03 April 2011 - 12:01 PM
ok cheers mate will have a look would this be part of the prob why my rear number plate light and tail lights do not work? dont they run on the same circuit
Edited by miniallsort, 03 April 2011 - 12:07 PM.
#12 leroy26
leroy26
  • 2,239 posts
Posted 03 April 2011 - 12:14 PM
not 100% sure on the back end, think there on the same fuse tho
#13 miniallsort
miniallsort
  • 4,723 posts
Posted 14 April 2011 - 08:27 PM
yeah mate they do run on the same fuse. sorted it now the two brown wires that connect to the fuse box dodgey connection
