Metal/alloy Floor Plugs
9 replies to this topic
#1 Ibexx
Ibexx
  • 225 posts
Posted 03 April 2011 - 12:50 PM
I've recently taken all the sound proofing of the floor (don't try this at home...). Whilst doing that I've damaged a few of the plugs that were in the floor. These plugs are made of metal and not rubber. I can find the rubber ones but not metal. I will be painting the floor and there will be no carpets, so I need the metal ones. Anyone know where I can buy them? Thanks!
#2 skoughi
skoughi
  • 1,199 posts
  • Local Club: Shetland classic car club
Posted 03 April 2011 - 03:15 PM
I would like to know as well, in the process of putting in a new floor. I'm putting carpets in and was going to put the rubber ones in but metal ones will be better and would have more confidence of them staying in and getting them sealed better as well.
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,080 posts
  • Name: Neil
Posted 03 April 2011 - 06:14 PM
Even steel ones if available could lead to problems. Plus i'm sure you would have to bond them in although i could be wrong there.
The rubber bungs work well and if you have any sort of issues with using them try fitting them with some sealant. The ones on Paddy are 36 years old and the one i popped out the other day is still supple and could still be reused.
#4 Ibexx
Ibexx
  • 225 posts
Posted 03 April 2011 - 09:28 PM
You're right, you do have to bond them in. For me the supple bit is the problem, paint doesn't like that.
#5 analogue_radio
analogue_radio
  • 4,897 posts
Posted 03 April 2011 - 10:13 PM
Been wondering this as well as I popped them all out on my '79, the surrounding holes and the metal plugs themselves were mint. Wasn't sure wether to replace them with more metal plugs, rubber bungs or weld them up.
#6 minikidx14
minikidx14
  • 1,387 posts
  • Name: Ross
Posted 06 April 2011 - 07:33 PM
If you want it to look good couldnt you weld over the holes, grind it back and filler over them? I think it would look nicer.
#7 xBR4DLEY
xBR4DLEY
    >>mine's still gay<<
  • 1,618 posts
Posted 06 April 2011 - 07:36 PM
You could do but then when your windscreen or heater leaks and waters all over the floor, you have no way of getting it out and then it would just rust the floor.
#8 Carlzilla
Carlzilla
  • 1,907 posts
  • Local Club: Splinters Mini Club
Posted 06 April 2011 - 08:20 PM
Just stick rubber bungs in there, i manged to pull my metal ones out removing soundproofing. theyre quite soft but supple so you shouldnt have any problems with it pushing paint off or whatever, theyre not that domed either to be honest.
#9 Tupers
Tupers
  • 4,156 posts
Posted 06 April 2011 - 08:55 PM
You could always put some plasticiser in paint them so it stays flexible.
As far as I know metal one's aren't available anymore.
#10 Ibexx
Ibexx
  • 225 posts
Posted 07 April 2011 - 03:05 PM
Thanks for the advice! I've tried it with th rubber plugs. Will see if the paint stays on.
