Clutch Clevis Pin / Master Push Rod / Clutch Peddle
3 replies to this topic
#1 karlos_junior
karlos_junior
  • 176 posts
Posted 04 April 2011 - 07:48 AM
Elf
1968
Pin not worn (damn it, whould have been the cheap option) but peddle hole is bigger:
is it poss to use some kind of epoxy to make the hole on clutch peddle smaller to match up with the size of the pin & master cylinder push rod? (saw this on an MG thread)
The other thought I had was to increase the size of the holes in the push rod to match the bigger holes in the peddle and use a bigger pin?
I know the best solution would be to get a new clutch peddle but I can find one locally and it will cost $10000,00000 to ship one here
any one got a solution>?
Im replacing my slave cylinder and want to fix everything clutch related while im at it
thanks in advance....
Karl
Edited by karlos_junior, 04 April 2011 - 07:50 AM.
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 04 April 2011 - 08:44 AM
If you really can't get a new one then I'd think you'll be best off completely filling the hole with weld and re-drilling it.
#3 karlos_junior
karlos_junior
  • 176 posts
Posted 04 April 2011 - 09:02 AM
great idea, I had thought about that, but did wonder how long the weld would last. Untill I can get a peddle I think thats prob my old option
cheers caravan man!
#4 irish.yobbo
irish.yobbo
  • 90 posts
Posted 05 April 2011 - 05:54 AM
Is this because the hole has been worn? They're usually elongated if they are.
You can expect a bit of movement, the only issue is if it going to break (in which case, enlarging the holes and pin won't be good). Having the hole a little bigger is not a problem really.
