Auto Gearbox
11 replies to this topic
#1 pat222
pat222
  • 21 posts
Posted 04 April 2011 - 09:29 PM
hiya every one, ive got a 1986 austin mini mayfair thats a 1ltre auto at the mini i want to keep it as auto because i have to drive using hand contriols ive got a 1275 engine to put in it, but was wondering what sort of power would the gearbox take i would like to go for stage 3 with a webber carb but what would you recomend?
any help would be gratefully thanks
#2 ShoutforJoy
ShoutforJoy
  • 738 posts
  • Local Club: TMF+, Automatic Mini Register
Posted 04 April 2011 - 09:46 PM
Good on you for sticking with automatic!
You are probably already going for the best upgrade (giving the biggest power lift) by replacing the 998 with a 1275.
A stage 1 upgrade (exhaust, manifolds and carb needle) will give up to 20% more power and is relatively cheap and straightforward to do. There are many further options beyond this (stage 2, uprated carbs - in fact almost any a-series engine tune can be done) but the further you go the less power increase you will get for you hard earned cash.
There are some big bore 1380+ autos out there!
Remember that with automatic gearboxes transmission losses are very high so horsepower figures at the wheels are going to be much lower than at the flywheel.
As far as I know there are no upgrades available for the autobox. But if you are going to spend £1000's on the engine it makes sense to overhaul the box at the same time. With any upgrade if there's something worn or slipping in the autobox an engine with more power is only going to make it worse.
There are some people who are of the opinion that you shouln't update an auto beyond stage 1 arguing that the auto box becomes a weak point. There doesn't appear to be much basis for this and many automatic experts disagree.
There are lots of topics on automatic engine upgrades on the Automatic Mini Register
hope this helps, Paul.
#3 Sheikh Pip
Sheikh Pip
  • 239 posts
  • Local Club: Sutton Coldfield Mini Club
Posted 04 April 2011 - 10:12 PM
You won't be able to put a manual engine on an auto gearbox without work to the oilways, so if you intend to fit a 1275 it'd be easier as a complete auto engine and box combined.
My 1275 auto has a stage 3 head and Hif 44 carb, it goes quite well for an auto and so far the auto box has coped OK!
#4 Tommyboy12
Tommyboy12
  • 2,255 posts
Posted 04 April 2011 - 10:15 PM
Might be a good idea to PM Guessworks. He seems to be our resident gearbox guru. Im sure they did a very quick auto in a recent Mini magazine/world. The guy used the gear selector like a semi-auto!
#5 pat222
pat222
  • 21 posts
Posted 05 April 2011 - 08:43 PM
[/quote]
yea i know i read about the diffrences some where on there but thanks for all the help
[quote name='Tommyboy12' post='2097134' date='Apr 4 2011, 11:15 PM']Might be a good idea to PM Guessworks. He seems to be our resident gearbox guru. Im sure they did a very quick auto in a recent Mini magazine/world. The guy used the gear selector like a semi-auto![/quote]
yea i was overweld with joy when i saw that i could use it as a semi auto lol
#6 MRA
MRA
  • 7,607 posts
Posted 06 April 2011 - 12:30 PM
Only the automatic is a transmission and not a gearbox :D
We have built 120+ auto's, but the parts are considerably dearer and some we get made in the states specially for our builds.
You can use the selector as you would a manual "stick" we hold stock of almost all the automatic parts for Classic Mini
#7 pat222
pat222
  • 21 posts
Posted 06 April 2011 - 05:04 PM
il make a note of your web page then but all i basicaly wanted to know whats the biggest engine and power stage i could run safely
without destorying the transmission, or is there a way of uprating it?
thanks agen for all the help
#8 MRA
MRA
  • 7,607 posts
Posted 06 April 2011 - 05:16 PM
I was only letting you know of the different types of possibilities, as Paul has already stated, 1380cc.... even 1430cc etc they are all possible, however you won't find the parts from anyone else as they are not available, we manufcature special parts for these engine specs, if yo uchoose to go down the route of a bigger engine, just remember that for any reliability you will need to get uprated clutch plates, bands and other parts to do the job, otherwise the standard parts that are available are getting worse by the day..... I have just recieved a consignement of steels form a well known automatic company and they are rusty.... not just a light surface rust, but deep rust that would simply ruin a transmission :D so yet again we are off to the drawing board :P
#9 pat222
pat222
  • 21 posts
Posted 06 April 2011 - 06:52 PM
I was only letting you know of the different types of possibilities, as Paul has already stated, 1380cc.... even 1430cc etc they are all possible, however you won't find the parts from anyone else as they are not available, we manufcature special parts for these engine specs, if yo uchoose to go down the route of a bigger engine, just remember that for any reliability you will need to get uprated clutch plates, bands and other parts to do the job, otherwise the standard parts that are available are getting worse by the day..... I have just recieved a consignement of steels form a well known automatic company and they are rusty.... not just a light surface rust, but deep rust that would simply ruin a transmission :D so yet again we are off to the drawing board :thumbsup:
right well added your site to me favourites any way probly goin go for the 1275 engine mainly because the mini i bought come with one, well i say a engine theres loads of bit missing
Attached File  _CDs7n2gBGk___KGrHqMOKoYE0gPGc96tBNPd4ChiU____12.jpg   50.31K   9 downloads
#10 gemmaliv
gemmaliv
    Starting My Mini Up
  • 4 posts
Posted 08 April 2012 - 04:37 PM
Anyone. Selling auto gearbox please
#11 SA MINI
SA MINI
    Previously known as shaunarmes.
  • 1,001 posts
  • Local Club: yet to join HAMOC
Posted 08 April 2012 - 04:57 PM
I'll be following this thread. As I have an auto too & looking to do the same in the future.
#12 ShoutforJoy
ShoutforJoy
  • 738 posts
Posted 08 April 2012 - 08:46 PM
Be very careful if you're buying a used autobox - you really need to see it running and drive it before it is removed, otherwise you'll be playing Russian Roulette. Old auto boxes usually get taken out when they start to give problems; you could fit a one just to have the same problems you're trying to sort.
Much better to get the box you have reconditioned. It might cost a bit more but at least you'll know the real condition of it. Contact Martin at MRA Minis (see above) and get some advice.
