Fitting 13x8 Wheels?
9 replies to this topic
#1 shep_cobain
shep_cobain
  • 157 posts
Posted 05 April 2011 - 08:18 PM
To fit 13x8 wheels what do you need to do?
Or is it a case of they just fit fine and you need to get arches to suit?
#2 glyn
glyn
  • 637 posts
  • Local Club: leyland mini club
Posted 05 April 2011 - 08:43 PM
depends what size tires they have on but you will need to trim the front wing and get suitable arches.
#3 minihewson
minihewson
  • 24 posts
Posted 05 April 2011 - 08:45 PM
You will need to cut the front arches so you can get full steering lock. and i would probably advise you to beef the front end up. i have got 13x8 on mine and have stiffened up with heavy duty tie bars and bottom arms. hope this helps.
#4 Cooperman
  • 23,354 posts
Posted 05 April 2011 - 08:46 PM
You will find that there are no tyres which will legally fit an 8" wide wheel for a road going Mini. You could get a slick racing tyre, but that would only be any good for track or hill-climbing use.
#5 glyn
glyn
  • 637 posts
Posted 05 April 2011 - 09:01 PM
you can still get continental tyres that fit (all be it a tad stretched) but the dunlop sp 9000 are no longer made
#6 Cooperman
  • 23,354 posts
Posted 05 April 2011 - 09:11 PM
Would that be 185x40x13 or 195/35x13 as they are the only sizes which would fit and give correct (more or less) gearing. You should certainly not fit a 175 width onto an 8" wheel. In fact the maximum wheel width for a 185 tyre should be 7.5"
A 185 or 195 width on a Mini would not be very good at stopping or cornering in the wet.
This was all covered in a thread a month or so ago.
Edited by Cooperman, 05 April 2011 - 09:14 PM.
#7 Andywade
Andywade
  • 328 posts
Posted 05 April 2011 - 09:16 PM
dont fit 13x8's unless your going racing or its just for show - they ruin the handling knacker your wheel bearings and cause alot of bump /torque steer.
My 13x7.5's were bloody awful going to downgrade to 12 x 6's I think
#8 Cooperman
  • 23,354 posts
Posted 05 April 2011 - 09:20 PM
They also create a lot of extra profile drag aerodynamically which knock a lot off your top and easy cruising speed and make the car use more petrol. Unsprung weight is also increased.
In fact, it's pretty much all a negative.
Widest wheels for good all round use are 6" with 165 tyres.
#9 glyn
glyn
  • 637 posts
Posted 05 April 2011 - 10:01 PM
the dunlops are 194/45/13 same as the continentals. i believe a well known tyre company who still sell these size wheels use the 175's but i would say that was a stretch too far.
#10 Cooperman
  • 23,354 posts
Posted 06 April 2011 - 08:39 PM
According to my wheel/tyre calculator, a 195 tyre can be fitted to an 8" wheel, but that is its maximum width.
a 175 should NEVER be fitted to an 8" wheel and it may be illegal to do so. It certainly wouldn't suit the tyre or car and would look a bit silly too.
