While looking around on the internet I stumbled across a link which had four files to download (can't find the link again). The four files turned out to be scans of an article written about three guys who built there own engine crane.
With the amount of miscellaneous junk lying around my dad's and gran's garages I worked out what I needed to make an engine crane. The article says you should be able to make one for about £110. With the stuff I have lying around I worked out mine would only cost £70. My engine crane should be able to lift 200 kg at its furthest reach and 500 kg at its shortest. This may not seem a lot however the bottle jack that I am using is a fairly weedy one. If you compare this to the cheapest one you can buy that is able to lift the same they cost about £130 and you still have to assemble it. If mine had a stronger bottle jack then it would be possible to lift almost 800 kg at its furthest reach. My Vauxhall engine and gearbox weighs approximately 160 kg.
I am not following these guys design religiously however have taken their basic idea. My main problem is making 24 mm diameter holes for my bolts to go through. For the main upright I will be using a 34 mm diameter hole saw and welding in a bush that I will turn on the lathe. As for the other it is a combination of 13 mm drill, hack saw and file.
Here is the article. The final two pictures are my engine crane tack welded together so far and the start of one 24 mm diameter hole. It should be finished early next week so can let you know how well it works then.
All credit goes to the guys who wrote the article in the first place.
(the box section at the bottom is not bent its just the photo)
Edited by M J W J, 07 April 2011 - 11:36 PM.
