Help Please Split Collar Washer?
3 replies to this topic
#1 gronkjor
gronkjor
  • 250 posts
Posted 08 April 2011 - 04:07 PM
Hi
I have to remove this :
But how can i do it? It seems impossible to get it free :-
Please help lads >_<
Rasmus
#2 mini13
mini13
  • 3,811 posts
Posted 08 April 2011 - 04:15 PM
it should come free pretty easily,
pull the disc it should come off no probs, if it is a bit stuck give the threaded bit a tap, use a bit of wood to cushion the blow so you dont knacker the thread.
#3 mykweb
mykweb
  • 543 posts
  • Local Club: does here count :)
Posted 09 April 2011 - 07:59 PM
usually if you wiggle the disk it will come out. You need to remove it before you pull the disk off.
another way but want you don't damage it. Spray some wd40 around it. then get a flat screw driver and knock it down, using the screw driver in the split. rotate it a tad and it should pop out
Mike
#4 gronkjor
gronkjor
  • 250 posts
Posted 10 April 2011 - 07:37 PM
Thanks for your help. Ended up using heat to get it free. I think it was the first time that the washer has been removed since the Mini was built - so it was pretty hard to get off.
But i succeeded in the end :)
