Supercharger Psi
5 replies to this topic
#1 Billys Bits
Billys Bits
  • 99 posts
Posted 08 April 2011 - 06:57 PM
does anyone know what psi the Vmax scart bottom pulley gives using the standard eaton m45 pulley also what is the best psi to run the chargers at?
#2 Grahamxx
Grahamxx
  • 188 posts
Posted 10 April 2011 - 02:14 PM
8-10 psi..
#3 Verbaliser
Verbaliser
  • 152 posts
Posted 10 April 2011 - 09:40 PM
It depends what engine the vmax kit is being bolted to, and what cam your using. If it's a standard 1275, then it's likely to be around the 8psi mark.
#4 Verbaliser
Verbaliser
  • 152 posts
Posted 10 April 2011 - 09:42 PM
Sorry forgot to say, vmax will machine a bottom pulley to your requirements, but this is generally to make is smaller to reduce the boost
#5 Grahamxx
Grahamxx
  • 188 posts
Posted 11 April 2011 - 04:15 PM
The supercharger pulley is the normal one to reduce, to either 15%, 17% & 19%. Depending on head work will effect boost pressure more. I'm running on our classic a Jonspeed crank pulley with a standard supercharger pulley and Swift tune cam for supercharged engines...
#6 Verbaliser
Verbaliser
  • 152 posts
Posted 11 April 2011 - 06:12 PM
I am a risk-averse tuner so reduced the boost for my set up!
