Corsa Van Problems
7 replies to this topic
#1 remi
remi
  • 154 posts
Posted 08 April 2011 - 07:09 PM
Im hoping one of you may be able to help, ive tried google but to no avail
I just bought a 04 plate vauxhall combo van.... however i have a slight problem
Every time i unlock the doors via the drivers side door, and then open it, the horn goes off repeatedly like an alarm, this stops once i put the keys into the ignition and start it....
the remote unlock key doesnt work, could that be the problem? maybe that deactivates the alarm at the same time?
thanks in advance
Remi
#2 col7778
col7778
  • 149 posts
  • Local Club: Not as yet
Posted 08 April 2011 - 07:28 PM
As you say i believe it might be the fob as i had a mondeo that would do the same when the battery went in the key.
#3 william.whyte
william.whyte
  • 0 posts
Posted 08 April 2011 - 10:31 PM
same as our corsa, it is the alarm because it needs to be deactivated with the remote, i dont know if it can be removed, maybe get a fob programmed or pop a new battery into the one you have it might work!
#4 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 09 April 2011 - 12:03 AM
If the battery in your fob has died, chances are it will need reprogramming to match your car.
#5 remi
remi
  • 154 posts
Posted 09 April 2011 - 07:33 AM
to re programme them you do it by inserting the key into the ignition, turning to 2nd key turn, then press the button then the car will lock and open, all done
however i cant get the back off the key fob to replace the key..... its not moving for toffee
#6 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 09 April 2011 - 08:56 AM
Doesn't the centre part of the key "slide out" of the top of the key to get the battery out on them?
#7 william.whyte
william.whyte
  • 0 posts
Posted 09 April 2011 - 10:49 AM
one of those small slot screw drivers slid into the slot on the key then a gentle push should popit apart.
#8 remi
remi
  • 154 posts
Posted 11 April 2011 - 08:58 PM
yeh it slides out but this wasnt easy at all.... took ages and lots of elbow grease
unfortunatly this didnt solve the problem, so i have no idea whats causing it or how to solve it. its rather embaressing to say the least lol
