when i drop the engine out of the estate, im gonna spend some time on the subframe and was thinking of a possible colour change?
would a good de-rusting, primering and dollop of hammerite be ok or am i better not attempting?
subframes!
mattyoung69
, Jan 08 2006 08:19 PM
7 replies to this topic
Posted 08 January 2006 - 08:19 PM
Posted 08 January 2006 - 08:33 PM
if the subframe is in good condition then yes hammerite should do the trick.
if not buy a new one.
hammerite do loadz of different colours so im sure u will find one that you want
Posted 08 January 2006 - 08:36 PM
You don't need to primer it though.
Posted 08 January 2006 - 08:45 PM
When I got me last one I hammerited it then waxyoiled.
Posted 08 January 2006 - 08:57 PM
cushty, fancy havin a bit of a contrast....body's gonna be black or charcoalish - will have a look in B & Q!!
thanks
thanks
Posted 08 January 2006 - 09:24 PM
Are you copying me?! :tongue:
I've just bought some silver smooth finish hammerite spray
i'm just gonna use a rotary steel brush in the drill and clean it up then just whack it on! :smartass:
Posted 08 January 2006 - 10:38 PM
rumbled, my gadget eyes saw u in the shop :fear:
im thinking poss blue or something - hammerite have a website - dangerous grounds is that!! :nugget:
Posted 09 January 2006 - 01:33 AM
Coloured subs. Who'd have thought it!? :grin:
Mine are going white to match the body (with a removeable front it'll be neat I figure)
I'm blasting mine back to metal, welding the seams fully, adding a couple of reinforcements (probably, although I haven't had a good look where yet), A ton of zinc rich primer, A coat of enamel, a rub down, another coat of primer, a top coat of white, and then a coat of petrol resistant clearcote.
White'll be a PITA on a subby, but I know it'll be the only way it'll look good with the front. Anyway, it'll never see rain! :tongue:
