8v Bmw Bike Head On 1275
Posted 09 April 2011 - 06:29 PM
is it worth it?
Posted 09 April 2011 - 06:46 PM
you'll see about 100-110hp from the std head and cam, with good torque low down.
Posted 09 April 2011 - 06:57 PM
Posted 09 April 2011 - 06:58 PM
when you say pistons machined is this for the valves? coulndt a decompression plate work to raise the head up so they do not touch the pistons
Posted 09 April 2011 - 07:04 PM
Posted 09 April 2011 - 07:05 PM
they are going to be a fair thickness of decompression plate! and yes they are for the valves110 even from the 8v? thats rather good,
Posted 09 April 2011 - 07:10 PM
Posted 09 April 2011 - 07:20 PM
fuel injection is past, present, and future
Posted 09 April 2011 - 07:57 PM
megasquirt might be the next direction then,
what is the average cost of this conversion?
Posted 10 April 2011 - 10:24 PM
Cost wise depends on how much of the work you can do yourself. Actual machining work is probably only a couple of hundred quid but there are some custom bits needed and some parts from other vehicles depending on what conversion you do. Most use the Ford Pinto verniers and cambelt tensioner but there are a couple of custom plates to seal the end of the head and parts of a Mini belt drive kit plus I think a custom toothed pulley for the crankshaft (different number of teeth to the one in the Mini belt drive kit).
Iain
Posted 10 April 2011 - 10:36 PM
There u go
http://www.specialis...mponents.co.uk/
Edited by minidream94, 10 April 2011 - 10:40 PM.
Posted 10 April 2011 - 10:58 PM
simon at morspeed done all the work and made an inlet which he started to produce, think i supplied him with the blanks. although the spacing of the ports on the head are different to the webers he matched all the flow capacities until they were even.
have just purchased original throttle bodies so will convert eventually but webers sound awesome
as for linkages went with a twin weber kit from aldon automotive
air filter wise will be using a k&n universal filter cost about £100
matt : )
