the thing is the front sits very high even with the hi-los at the lowest point.
I have mini spares red dot cones installed, as per mini spares "if using these on 10" wheels with Hilos cut 3/4" off the end of the centre threaded bolt of the old type Hilo with a circlip as it will bottom out on the cone spring face and the car will sit high, for extremely lowered cars the hilo face will also need machining a few mm"
This is not my case as I'm running 13's
Also was told that if I have the wrong knuckle joint fitted (post 1990 with spacer) the suspension will sit high.
I'm aware that they haven't been broken in yet and the pro-motive front end is lighter but as you'll see from the pictures when comparing to the rear it just makes no sense for it to sit this high (even with the car stripped)
Anyone had this issue, help would be greatly appreciated
Rear at lowest setting :
This the front
