Put an interiour in and go drive it.
It will drop.
The rear will probably end up rubbing to be honest, and the front will be pretty close to the arch.
The problem is they are harder than the standard cones, and you are useing a lighter engine, so there is less pressure on them to compress them.
Just a thought.
On the off chance that the front doesnt settle as low as you would like. Take the trumpet back out, remove the threaded bar section from it and have the 'pointy end' skimmed down on a mill.
1mm should lower the car 5mm at the front so a little can make a big difference.
ONLY do this if the thread inside the trumpet goes all the way through through. If its just a section at that end which is threaded you will weaken it, and could make it potentially dangerous.
Edited by Burnard, 10 April 2011 - 11:51 AM.
