Hi,
My brake compensator/pressure reducing valve/brake bias valve or any other name it is known by, has packed up there is no brake fluid coming out of the port feeding the rear brake line.
What I want to know is instead of replacing it can I bypass it by linking the top of my dual line master cylinder GMC 227 "yellow tag" to the front brakes and the bottom of master cylinder to the rear brakes and fit a brake bias valve on the rear brake line to adjust for lock up. There by removing the compensator from the system and hopefully getting a more efficient system.
Many Thanks
Brake Bias Valve
fastroadie
, Apr 11 2011 09:46 PM
2 replies to this topic
Posted 11 April 2011 - 09:46 PM
Posted 12 April 2011 - 12:58 PM
If you Google calvers corner, there is an article on rear brake bias.
Hi,
Many Thanks
[/quote]
Hi,
Many Thanks
[/quote]
Posted 14 April 2011 - 08:18 PM
Nice one, read the Calver corner article. Think I will just bypass the compensator and fit a bias valve.
