4 Pot Calipers
Posted 12 April 2011 - 02:47 PM
i noticed once the pads were on then they moved around willy nilly,
is there something im missing or are they meant to do that?
cheers
Posted 12 April 2011 - 03:43 PM
im sure someone will correct me if i am worng but thats what i have been told that the should have slight movement
Posted 12 April 2011 - 03:59 PM
cheers
Posted 12 April 2011 - 05:47 PM
Pads always touch the disc so theres no need to worry about them i have them on mine and I did notice this untill the brakes are bled and are working as the pistons hold the pads against the disc with little pressure but it stoops them rattlingcheers i meen that even while on the car they are free to move against the disk i was wondering if there is a spring or clip which stops them hitting the disc when the brakes arent on
cheers
Posted 12 April 2011 - 08:39 PM
Posted 12 April 2011 - 08:52 PM
Pete
Posted 12 April 2011 - 09:01 PM
Stating the obvious but you have got the retaining clip under the pins havent you .Asuming its the same as my metro turbo 4 pots.
Pete
They have a large split pin that holds both the pads in. Not the best engineering
Posted 12 April 2011 - 09:43 PM
http://www.minispare...=...8314&title=
Posted 12 April 2011 - 10:10 PM
The Anti sqeal springs/plates it hasn't got them in I might try fit some thoughBut i ment these but couldnt for the life of me remember what they were called
Posted 12 April 2011 - 10:24 PM
Posted 12 April 2011 - 10:25 PM
Posted 13 April 2011 - 12:53 PM
No body else appeared to have the same problem and Mini Sport said they had never had an issue, I tried another set of pads to make sure, which made no difference.
Anyway, I have used the standard metro sprung steel anti rattle clips that fit between the pads and the split pins. My calipers are non vented and it was hard to source them at first but Mini Spares got some in, the vented caliper type were actually easy to get at the time so shouldn't be a problem.
Once these were fitted, it was so much quieter, and such a relief.
I have the slotted disks which also appear noisy/juddery under braking, but next change of pads I will try some plain disks from MRA and see if they are any better.
Posted 14 April 2011 - 10:51 AM
Posted 04 November 2012 - 08:28 PM
