Sand Blasting - Wrapping Vinyl - Window Tint And Powder Coating
Posted 12 April 2011 - 03:39 PM
Many colours avalable. Gloss, Matt, iridescent and Carbon fibre.
Wraping vinyls from only £14.99 Per Metre
Wraping services also avalable for small items.
Window Security Film
This film is designed to provide car owners with an economical and effective means of significantly strengthening glass against accidental damage and vandalism.
The clear film will not alter the appearance of glass but will to hold shards of fragmented glass together, reducing the risk of injury, should the glass be smashed.
All Window Security Films have been tested and are ANSI Z97.1-1984 certified.
Security film from only £9.99 Per metre x 760mm
Window tint
Our window tint is a premium non-reflective charcoal window tint film. This effective solar and UV protection film is non conductive so it will not interrupt rear window GPS, radio and security systems. Available in 4 different types. 5% 20% 35% and 50%
Window tint from £10.99 per meter
Powder coating
I can powdercoat most metal items under 15" square.
Wheels 10-13" from £19.50 Each
Inlet manifolds from £8
Rocker covers from £9.95
Sand Blasting
Wheels from £7 each
Manifolds from £5
Rocker covers from £5
Whole shell from £200
Message for more details.
Posted 14 April 2011 - 07:44 PM
Posted 14 April 2011 - 08:41 PM
how much for a full mini in matt grey
I havent done a mini yet so not sure on the amount of vinyl needed. however i would say about 25m to do the whole car which would work out at £212.50 + £6.99 p&p = £219.49
Posted 14 April 2011 - 09:18 PM
Posted 14 April 2011 - 09:29 PM
Posted 14 April 2011 - 09:54 PM
Without measuring i would guess the roof and bonnet would take 4m which would work out at £40 + £6.99 = £46.99. If you could get the size of them both i could work out an exact price.How much would it cost for matt black to cover a clubby bonnet & roof?
how long will a wrap last and what surface can i apply too willi have to primer my minu first or will it stick too filler ect.
It should last 7+ years but that could be shortened if it isnt looked after properly. It should be kept clean but not using a presure washer as this could damage the wrap. As long as the filler is smooth and clean it will stick fine.
Posted 28 July 2011 - 11:09 PM
Message me for a quote.
Unfortunatly i can still only powdercoat small (under 15" square) items currently.
Posted 29 July 2011 - 02:58 PM
cheers
Posted 29 July 2011 - 06:23 PM
Although i can get hold of some budget film if needed but i dont really recommend it.
http://www.johnsonwi...c_charts_RG.htm
Posted 29 July 2011 - 06:35 PM
Posted 29 July 2011 - 09:26 PM
Posted 31 July 2011 - 08:09 AM
Posted 02 August 2011 - 12:23 PM
Where abouts are you based?
Posted 02 August 2011 - 05:54 PM
do we post the parts off to you and then you send them back or do we bring the parts to you?
Either is fine, Posting is better as i might not always be in when someone comes. Im based in weston-s-mare just south of bristol.
Posted 23 September 2011 - 09:07 PM
