Removing Alternator For Racing
Posted 13 April 2011 - 08:23 AM
Is there any changes I need to make to the electrics or is it just a case of covering the socket that went to the alternator?
Regards
Alan
Posted 13 April 2011 - 08:38 AM
Posted 13 April 2011 - 08:39 AM
I'm not an electric genius but that how I understand it before I potentially get ripped apart by a grumpy ass!
Edited by C4NN0N, 13 April 2011 - 08:40 AM.
Posted 13 April 2011 - 08:48 AM
Remember that the alternator keeps the system at about 14.4v unless under major load, so your battery at say 12.5v (about 2v lower which is 13% lower) may struggle to do anything well, and your coil will be seeing 13% less voltage which could mean you get a smaller spark. Also you have the constant drain of fuel pump etc which could lower the voltage further, and should you happen to stall or need the wipers etc... well it's food for thought!
and with all them issues its lowering BHP
Posted 13 April 2011 - 08:54 AM
I guess we'er limited on how to do that on a fwd mini though!!
Posted 13 April 2011 - 08:57 AM
Posted 13 April 2011 - 11:28 AM
The voltage of a fully charged lead acid cell in 2.2v, so the battery voltage fully charged is 13.2v. A fully charged Varley or even small car battery will run the car all day at a hillclimb/ sprint. Just don't start it 25 times.
Posted 13 April 2011 - 11:30 AM
If you want to to go uphill faster, you would be better off looking to save weight, like going on a diet.
Posted 13 April 2011 - 12:02 PM
Regarding spark... by the time the battery voltage impacts the spark voltage you are well down on the cells. The spark voltage is controlled by the gap at the spark plugs, not the coil output voltage, and not by the battery voltage (at least not until the battery is very near being completely discharged).
I was actually going to post what Ivor Badger did. Check with your race sanctioning body regarding whether or not the alternator has to be present AND whether it has to be functional. Those are two separate points... present & functional. If you are allowed to run without an alternator, jump start the engine off another battery when possible. If you start off a different battery, the engine will be able to run for a very long time using the one in your car. Engine starting is what really sucks the power out of a battery quickly.
The comment was made earlier that you may "only" pick up 3 or 4 HP without the alternator. Taken as a percentage of the engine output that is nothing to make light of as it would be significant. However, the gain would not really be that high. Power = Watts = volts x Amps. Let's say your alternator puts out 30 Amps immediately after you start the engine (to recharge the battery). Let's also say that the alternator is putting out 14.5 Volts (not unreasonable). 14.5 x 30 = 435 Watts. 746 Watts = 1 HP, therefore, you are saving 0.6 HP (plus frictional losses for the bearings and belt drive). Chances are that if you allow the engine to warm up a bit before your race (recharging the battery and lowering alternator current output), you would see almost no power lost to the alternator during your race.
Posted 13 April 2011 - 01:18 PM
If the alternator is only providing power for the ignition system and assuming approx 50% efficiency of the alternator, then you will gain in the order of 0.1 bhp by disconnecting it. Perhaps double this if you include windscreen wipers.
Have you weighed an Alternator/dynamo?
Posted 13 April 2011 - 02:10 PM
Posted 13 April 2011 - 02:41 PM
would manage to run a whole meeting on a fully charge battery, that would include 3 maybe 4 5 lap races with cranking of the same battery. If you used a slave battery for starting then we never had any issues.
Granted not alot of electrics in a grasser, ignition, fuel pump, some maybe a water pump, so depends on how long your runs are for
matt : )
Posted 13 April 2011 - 10:46 PM
Curious about the proshaft trick.... as the current consumed will have to be replaced, and as far as I know the alternator is more efficient at higher speeds than at lower speeds ..... and for every Amp of current that is required to be charged that will require a proportional amount of engine power or indirectly propshaft power to generate it...
There are of course more efficient alternators, I am lead to believe that the Kubota alternator is very efficient.
Posted 14 April 2011 - 05:24 AM
Use a Nippon Denso, at high revs they shut off the charging circuit automatically and effectively become just a tensioner which frees up (minimal) hp
Paul
Posted 14 April 2011 - 06:58 AM
