Roller Painting
#31
Posted 16 April 2011 - 08:06 AM
sorry i knw very little about painting
#32
Posted 16 April 2011 - 08:15 AM
do u sand ur paint even on ur finish coat
I would say no, dont sand the top colour coat, it should be a fairly smooth finish anyway. Put maybe 4 coats of clear on then sand it back using 1000 wet and dry, with water and some car shampoo. Then do the same with some 1200 then 2000 then polish. will look $1m
#33
Posted 16 April 2011 - 08:19 AM
#34
Posted 16 April 2011 - 08:22 AM
u say clear i presume u mean laquer
Yep
#35
Posted 16 April 2011 - 08:23 AM
#36
Posted 16 April 2011 - 08:27 AM
will laquer not flake when i sand it,, iam gona try this when painting my dads tractor first
No, you need to leave it 2 weeks before flatting/sanding, but no it should not flake, i was going to suggest gen old panel and try it first to make sure it wont react but I guess the tractor will be fine.
#37
Posted 16 April 2011 - 08:42 AM
when I did my mini I got the paint mixed to the vin plate colour (Flame Red = COF) and the same for the undercoat also. And the roof is just Taxi Black.
All the paint and thinners were mixed for me by turners trade paints (http://www.turnerstradepaints.co.uk/).
Real helpful folks with loads of advice (Bill the brummie helped me lots on the phone).
If any of you just want to use rustoleum, etc then I'd still get some synthetic thinners as I tried it with smooth rollerable hammerite and it sagged or sometimes wouldnt even coat.
Thinners would have helped the paint flow so I wouldnt have loaded the roller so much.
When I first used the nice new coach enamel I was amazed at the coverage and quality of the shine. well worth the money.
1lt flame red undercoat
1lt flame red coach enamel
1/2 lt taxi black enamel for the roof
some synth thinners
some rollers
Cost me About £75 inc postage and worth every penny.
#38
Posted 16 April 2011 - 11:06 AM
Paint was £21 posted, for 2.5 litres, should be enough to do the car. Roller was £3, and used two or three cans of primer at four quid each, and some wet and dry.
Not gonna bother flatting it back, or making it look perfect, because it's Matt Black. It'll keep the rust away, and looks miles better than the crappy coat of turquoise that was on it before. Nice colour, just applied badly...
#39
Posted 16 April 2011 - 06:56 PM
#40
Posted 16 April 2011 - 09:57 PM
#41
Posted 16 April 2011 - 10:13 PM
#42
Posted 16 April 2011 - 10:27 PM
sounds good i never thought you could do this, i take it you make it metallic with lacquer?
Ste_J
You could always, paint the dulux on and then clearcoat over the top then wet sand that back and polish, would look like a proper job then too.
You DON’T need to lacquer it, just polish.
The metallic, is in the paint itself, but you also have the thin it down slightly more than you would a solid colour and makes the paint not cover as well. Witch just makes things harder with more coats needed, and if you get any sort run or mark, painting over the top won’t cover it. Instead you have to keep sanding back the whole panel to fix it and start all over again.
Rustoluem and dulx (non-drip gloss) are both enamel based paints, therefore if you try and over coat them with anything but enamel lacquer, it WILL react. Plus it’s not really needed anyways.
#44
Posted 16 April 2011 - 10:43 PM
#45
Posted 16 April 2011 - 11:00 PM
which sort of dulux paint to i ask for?
non-drip gloss
