Rose Joint Bottom Arms
Posted 14 April 2011 - 08:47 PM
Posted 15 April 2011 - 09:58 AM
Posted 15 April 2011 - 10:34 AM
Posted 15 April 2011 - 11:19 AM
http://stores.ebay.c...sid=p4340.l2563
While your on get some sort of rubber boot to protect the joints from road grit, etc and they will last much longer
These sort of things making sure you get the right size for your application
http://cgi.ebay.co.u...=item2556b4d886
David
Posted 15 April 2011 - 11:26 AM
Posted 15 April 2011 - 11:45 AM
We have been supplying our rose jointed bottom arms with a fully enclosed rubber boot for over 20 years....
Posted 27 April 2014 - 01:54 PM
Hi I know this is a old post but what size boot do I need to fit the bottom arm rose joints from minispares?
Minispares do not have any in stock
Posted 19 February 2016 - 11:55 AM
This is an old reply..... the boots are sized to the joint, ie a spherical bearing with a bore and thread size of 1/2" requires a 1/2" boot, the only issue is odd sizes bearings, for instance 5/8" thread / 1/2" bore would need a special boot or maybe go for the larger (5/8) if nothing else is available
