Removing the Fan to get more Power
Posted 09 January 2006 - 03:18 PM
I think it was Dan that mentioned you should never remove the mechanical fan and someone else claimed that it's not a problem.
Who's correct?
The reason I ask is that I would imagine the engine would gain a bit of power if it was removed and I only use my mini for trackdays - therefore no idleing in traffic.
Will enough cold air get to the engine on a track where the average speed is well over 30 mph?
Grateful for any advice from someone who's tried it.
Posted 09 January 2006 - 03:27 PM
If you have a good radiator (pref front mounted) and electric fan (when sitting in the paddock) you should be fine..
TTFN,
Dave
Posted 09 January 2006 - 03:53 PM
Trust me, if you were to remove the fan (mechanical or electric) form the side of the engine, our engine would overheat fairly quickly!! The exception to this would be if you have a radiator at the front! However I think you still need a fan to cool the engine when sat in traffic, etc.
You only really need to fit a electric fan instead of a mechanical one when your looking to find every last bhp, as swapping them over will only find you 1-2bhp! And for most people, its not worth the £60-70 outlay!
Posted 09 January 2006 - 04:10 PM
The alternative is to change the pulley wheel on the water pump, if you use the larger diameter ( you may already have it ) pulley, obviously the fan goes round slower, and so does the water pump..
Posted 09 January 2006 - 04:19 PM
Posted 09 January 2006 - 04:22 PM
Posted 09 January 2006 - 04:39 PM
Posted 09 January 2006 - 04:41 PM
Posted 09 January 2006 - 04:42 PM
Posted 09 January 2006 - 04:47 PM
Posted 09 January 2006 - 04:56 PM
Your best off saving your cash and using it on something that will really make a difference, cam, rockers, head, etc.
Or invest in any of Vizards books, so you can learn how to modify standards parts yourself.
Posted 09 January 2006 - 05:12 PM
Posted 09 January 2006 - 05:41 PM
Posted 09 January 2006 - 06:17 PM
So you could then run without an alternator and just take a few spare batteries with you
or you can modify the alternator to 'cut out' - either manually controlled or a microswitch on the throttle, etc..
Fit a front rad and fan arrangement (MPi, Metro, Rovers, etc) and be done with the side mounted stuff
- could go with an electric water pump too... every little bit helps...
TTFN,
Dave
