Solid Mounting Exhaust & Engine Mounts
8 replies to this topic
#1 TopCatCustom
TopCatCustom
    Previously known as C4NN0N.
  • 1,134 posts
Posted 15 April 2011 - 01:24 PM
Hi, What options do I have for engine mounts- are there decent harder than standard ones like polybush ones or are standard ones best? I don't want the engine to be completely solid mounted but I do want it to be very firmly set in place, so will be using a pair of good steadies at least.
Also as the engine will effect how well the exhaust lasts due to how much it moves, can I solid mount the exhaust if the engine has good steadies or is rubber mounting best? Will be rallying so don't want it flopping around as rubber mounts can break too easily sometimes.
#2 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 15 April 2011 - 03:32 PM
You can get polyflex engine mounts and engine steady bushes, go on ebay, there's loads!!!
Exhaust should stay rubber mounted, as the engine rocks the exhaust moves a lot, so if you solid mount you're going to cause fatigue and early joint failure, particularly on the manifold to intermediate pipe joint.
You can also polybush or solid mount the subframes to stiffen things up a bit.
#3 TopCatCustom
TopCatCustom
  • 1,134 posts
Posted 15 April 2011 - 04:38 PM
Front subframe will be solid mounted, I did wonder whether to put a very short flexi pipe in after the Y piece but it will probably do more harm to flow than good .
#4 charie t
charie t
  • 3,153 posts
Posted 15 April 2011 - 06:14 PM
miglia have a solid mounted rear box and a flexi joint where you describe.
Why do you want to solid mount the engine? decent engine steadies will be a good start.
Better clutch control can prelong engine steady bushes too
#5 Timinichelsea
Timinichelsea
  • 215 posts
Posted 15 April 2011 - 07:04 PM
Sorry, but they dont.
Exhausts are normally just mounted at rear, some are on hangers but most are solid.
Also they generally run std engine mounts, we did use the quick release poly bushes for a while but they were more of a pain than they were worth.
#6 Ibexx
Ibexx
  • 225 posts
I've very recently done abou the same. For me it was because of the internal gear change that I'm installing. What I would suggest is the following:
- An ultimate engine steady at the top, one side sollid one side poly
- another top engine steady. I've used a Specialist Components one which is solid and one side poly
- normal rubber engine mounts, don't go near the poly ones on eBay, they are bad quality and will fall apart. The solid ones apparently do quite a bit of damage.
- two gearbox steadies solid on one side ans poly on the other, available from Minispeed
For all poly bushes use polyflex, not the cheap alternatives. I will also be solid mounting my exhaust and think/hope the above is enough to prevent breaking the manifold.
Hope this helps
#7 TopCatCustom
TopCatCustom
  • 1,134 posts
Posted 16 April 2011 - 09:47 AM
I said in my original post I do not want to solid mount the engine, and decent clutch control will be hard when thrashing the hell out of it rallying...
Hope this helps
That helps thanks, internal gear change is also on my list of priorities, does it work ok without the additional steady rod that they normally have under the selector rod?
How did you mount the exhaust? Mayeb rubber at the front and solid mounted under the rear subframe would work ok?
#8 Ibexx
Ibexx
  • 225 posts
Posted 16 April 2011 - 05:19 PM
I haven't installed it yet. I bought the one from Force Racing. Will be about a 4 weeks until testing. Can let you know how it works out if you want. But I 'borrowed' the idea from a guy on TM who has a great mk1, so it should work.
Same for the exhaust, not tested yet. I will be removing the rubbers at the back so the exhaust can (in combination with the internal gear change) come higher in the tunnel and therefore the car lower. Will be tubbing the rear arches too.
#9 Slinky1313
Slinky1313
  • 197 posts
  • Local Club: Sutton Mini Club
Posted 16 April 2011 - 05:42 PM
i was wonderin this before aswell, cant remember exactly what the reply was but it was somethin along the lines of, polyflex for the engine mounts, solid mount top of the subby with poly at the bottom mounts, and according to one guy he recons the late cooper steady's had the best bush's.
