Clamp Meter Work On 12v Circuits
9 replies to this topic
#1 amarcd
amarcd
  • 434 posts
Posted 16 April 2011 - 09:24 AM
Hi,
In relation to a previus post i made regarding running a race mini without an alternator, i may just give it a go. As an easy check on the battery rather that take the top off the sealed battery box would a clamp meter work to measure the voltage?
http://cgi.ebay.co.u...=item48371fef4b
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 16 April 2011 - 11:51 AM
message the seller and ask if it works on AC (mains) or DC (battery) power or both
#3 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,147 posts
  • Name: Sean
Posted 16 April 2011 - 01:28 PM
Don't clamp meters measure ampage?
#4 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 16 April 2011 - 01:55 PM
i have a cheap AC tester that lights up with the presents of voltage with out touching something live
#5 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 16 April 2011 - 01:56 PM
EACH METER DETECTS AND MEASURES THE ELECTRICAL FIELD AROUND A WIRE, WITHOUT DIRECT CONTACT, AND HAS THE FOLLOWING FEATURES;
DIODE TEST
LCD DISPLAY
AC CURRENT - 0.1A TO 1000A
AV VOLTAGE - 1V TO 750V
DC VOLTAGE - 1V TO 1000V
54mm JAW OPENING
AUDIBLE RESISTANCE 100m 0HM TO 20k 0HM
CONTINUITY TEST 50+25 0HM WITH AUDIO TONE
INCLUDES CARRY CASE
TESTING LEADS
BATTERY
it should work
#6 amarcd
amarcd
  • 434 posts
Posted 16 April 2011 - 02:01 PM
I have ordered it now. It would be great if it works with out having to use the probes to actually touch on the battery terminals or bare wires.
#7 Shifty
Shifty
  • 13,147 posts
  • Name: Sean
Posted 16 April 2011 - 05:45 PM
I'm fairly certain that it won't!!
I know the clamp meter I've got at work won't, it will measure the amount of current being drawn by a heater and if you know the voltage you can then work out the wattage of the heater.
It will also detect if a phase is down or a circuit is broken. I've also got one of the pen type as well and that just detects if theres power there.
#8 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 16 April 2011 - 07:01 PM
It won't work. Will put money on it. It will measure voltage by using the test leads only. The clamp part will only measure current, and only AC current at that.
#9 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 16 April 2011 - 07:09 PM
DC current clamp meters cost a lot of money, you are very unlikely to get one for this price. But current isn't what you want to measure and I'm not sure that any meter can measure voltage indirectly. A volt pen will only give you an indication of the presence of a corona, it can't measure the voltage.
#10 Wil_h
Wil_h
  • 3,244 posts
Posted 16 April 2011 - 10:01 PM
Clamp meters only measure current, as stated above, voltage will be measured with probes. I personally use a LEM HEME 2040 for similar measurements, but these are more like £350.
The best thing to do would be to put a couple of 4mm banana sockets on the battery box to use as monitoring points.
Personally I never check mine, but as I have a seperate starter battery I already have easy access to a socket to stick a meter on if required.
