iv got a mini 1000 and want to put twin su carbs on them there all fitted but need a hand on fuel pipes and breathers were do thay go ????
Twin Su Carbs
minipaul11
, Apr 16 2011 01:19 PM
4 replies to this topic
Posted 16 April 2011 - 01:19 PM
Posted 16 April 2011 - 02:48 PM
Twin Hs2 have a breather pipe inlet on the inside of carbs. I just put my beathers to atmosphere through breather filters. Sone people recommend putting breathers hrough the carb to such the gases outof the block. I haven't noticed any difference.
Matt
Matt
Posted 16 April 2011 - 03:59 PM
thanks what about the fuel pipes?Twin Hs2 have a breather pipe inlet on the inside of carbs. I just put my beathers to atmosphere through breather filters. Sone people recommend putting breathers hrough the carb to such the gases outof the block. I haven't noticed any difference.
Matt
Posted 16 April 2011 - 04:24 PM
If you have only one engine breather, then you connect this to a Y piece and then to each carb.
If you have 2 engine breathers you connect both to a T piece and then a short hose to a Y piece and then to each carb.
There is a specially made steel fuel feed pipe for the original twin carbs which was connected to each carb and the supply with 1/4" fuel hose. If you do not have this, then use a 1/4" 6mm plastic T or Y piece whichever suits the layout best and connect with 6mm fuel hose.
Posted 16 April 2011 - 04:33 PM
You can see the connecting fuel line here.
