Creaking Sound From Rear Suspension
Posted 17 April 2011 - 03:40 PM
The sound has been there a while. I thought it may have been the rear dampener bottoming out as i had the lowered Th car. SO replaced with gaz adjustable and the problem persisted.
Next I thought it could be the non genuine hilo - i thought the thread was protruding the hilo and fouling the middle of Th rubber cone. I raised the car toady and the noise is still there.
I also softened up the dampeners but the noise is still there.
Radius arm has been greased and yip you guessed it still noisy.
it only seems to happen at low speed. on a sharp corner or the moment i accelerate away from a stop. If you rock the car it also makes Th noise.
any ideas?
Posted 17 April 2011 - 04:35 PM
Posted 17 April 2011 - 05:16 PM
Posted 17 April 2011 - 09:16 PM
Or can anyone confirm or negate the suggestions above!
Posted 18 April 2011 - 12:39 AM
Posted 06 September 2011 - 10:48 AM
Did you ever resolve this issue? My Mini has been doing a similar thing for a while now and is really starting to get on my nerves as the noise is almost constant (I only drive it occasionally tho, so not bothered to investigate the noise before now). As it's from the near side I wondered if it could be the fuel tank brackets making the noise or something like that?
Cheers,
Steve
Posted 06 September 2011 - 12:11 PM
Hi,
Cheers,
Steve
Yes resolved, Turned out the radius arm pin was slightly siezed, and not allowing the arm to drop as fully and as smoothly as it should. Hence the creak.
Pin replaced and problem solved!
Posted 06 September 2011 - 03:39 PM
