Supercharged 1275. First Run Blown Head Gasket
Posted 19 April 2011 - 11:47 AM
So i got my supercharged 1275 running and driving down my drive last weekend. Sounded great with the straight cut drops. The engine has not been set up (mixture and timing) but was good enough to run. I put my foot down a bit and it blew the head gasket. It blew out of the side by the factory fitted steady bar. So much so it was popping out the side. I took the head off to inspect the gasket and the metal ring has mis shaped slightly next to the hole where an 11th stud would be. The gasket is a bk450 and i have reused the existing head studs. I havn't checked the block and head for flatness yet.
I was just wondering whether people generally replace head studs and if so which ones would you go for, there seems to be a big difference in price for standard and uprated stud kits on mini spares.
Also are bk450 head gaskets up to the job?
Thanks in advance
Posted 19 April 2011 - 11:59 AM
What is the rest of the engine / head spec? How have you lowered the compression ratio?
I'm presuming you've not just bolted a supercharger onto a standard 1275. If you have and it is still ok, although not ideal at least use something like http://www.minispeed...c-120thou-thick to lower the copression.
Edited by Bullet, 19 April 2011 - 12:01 PM.
Posted 19 April 2011 - 05:44 PM
Do you have a photo of the failure? it might help diagnose the failure.
However, failures out of the side are generally caused by two things:
1) Under torqued head (check your torque wrench is reading right)
2) Warped head.
Too much boost, too much ignition advance or too high a CR will almost certinally end in detonation and a different type of gasket failure to the one you have experienced.
I would advise that you don't go blasting around without setting the advance and fuelling, you might get away with it on a no forced induction car, but it's asking for trouble with a super or turbo charger.
Posted 19 April 2011 - 06:38 PM
Fit ARP studs, 11 bolt the engine and you should be ok, how much boost are you running? I fitted copper head gaskets with copper head gasket spray and they are solid.
Posted 19 April 2011 - 07:15 PM
Posted 20 April 2011 - 11:13 AM
I have had the chambers in the head enlarged so no de-compression plate.
I have made my own kit so i'm not 100% sure what boost it's going to be running at the moment, but i have a selection of pulleys i can use if it is too high.
What i am trying to decide is whether it is nescesary to have 11 studs and arp bolts? presently i am using the old used studs (only 9). Have any of you ran FI engines with 9 standard studs? would it be better if i got 9 uprated studs or do you think i need 11, i know theres probably no right or wrong answer here but i would just like to get a feel for what other people have done,
cheers
Posted 20 April 2011 - 11:36 AM
Posted 20 April 2011 - 11:47 AM
Posted 20 April 2011 - 01:00 PM
Posted 20 April 2011 - 02:56 PM
Posted 20 April 2011 - 03:34 PM
i have worked out the compression ratio to be 8.5:1 by filling the relevent spaces with parafin and measuring the volume with a seringe, so unless my calcs were wrong i reckon it should be ok. The head has been worked a lot and the pistons are dished as standard. but i would be interested in rerading that thread, if you know the link could you post it??
any other thoughts on head studs??? what have other people used on their forced induction engines???
cheers
Posted 20 April 2011 - 06:12 PM
Posted 20 April 2011 - 07:27 PM
