Breaking 1994 1275 L Reg Mini Sprite
Posted 19 April 2011 - 03:54 PM
CONDITION OF ITEM GOOD
PRICE OF ITEM REQUIRED
LOCATION OF ITEM hertfordshire
DESCRIPTION OF ITEM
sprite interior with no door cards or head rests £30 pick up only
set of 4 white minilight alloys with good tyres £130 can post for £35
black carpet set £30 + £11.25 p&p
sound proofing for under the carpets £10 + £11.25 p&p
black bottom dash rail £15 + £11.25 p&p
power flow exhaust £25 + £11.25 p&p
spare wheel with good tyre £15 + £11.25 p&p
boot lid £20 + £11.25 p&p
n/s door £50 pick up only
o/s door £50 pick up only
front subframe £50 + £15 p&p
gear linkage £15 + £11.25 p&p
steering rack £25 + £11.25 p&p
discs, drive shafts, hubs etc £50 can post for £35
adjustable suspension & shocks £35 + £11.25 p&p
complete n/s radius arm £25 + £15 p&p
complete o/s radius arm £25 + £15 p&p
front suspension arms £5 + £6 p&p
adjustable tie bars £10 + £5.00 p&p
lower suspension arms and pins £10 + £6.00 p&p
cooper steering wheel £15 + £6.00 p&p
rooflining bars £20 + £11.25 p&p
late plastic type heater box with no heater matrix £25 + £8.00 p&p
horn £5 + £3.00 p&p
sunvisors £15 + 4.00 p&p
front wiper motor £20 + £11.25 p&p
steering cloumn ignition lock & key £10 + £11.25 p&p but it is bent as it has been removed from an accident damaged car but the ignition lock still works fine.
bonnet hinges £10 + £3.00 p&p
boot and door catches £5 + £3.00 p&p
brake master cylinder and pedal box £40 + £11.25 p&p but the pedal box is bent as it has been removed from an accident damaged car.
wiper / indicator stalks £25 + £5.00 p&p
chrome wiper arms £5 + £3.50 p&p
mk2 rear lights £20 + £6.00 p&p
chrome mk1 boot lock £10 + £3.00 p&p
chrome mirros £5 + £4.00 p&p but does have one black clip missing
interior light £5 + £2.50 p&p
chrome door scoops £4 + £2.50 p&p
chrome cooper badges £5 £2.50 p&p
subframe bolts and alloy tear drop mounts £6 + £4.50 p&p
chrome interior door handle set £10 +£4.50 p&p
bonnet catch and cable £10 +£ 3.50
complete front to rear wiring loom £25 +£8.00 p&p but does have a few cuts in the loom as it has a mk1 speedo fitted
windscreen air vents £15 + £5.00 p&p
black door pockets £15 +£4.50 p&p
petrol tank and fuel sender £10 + £11.25 p&p
petrol tank strap £5 + £4.00 p&p
washer bottle and pump £5 + £3.50 p&p
rear fog light £5 + £3.00 p&p
chrome column bracket £5 + £3.00 p&p
clutch master cylinder £20 +£4.00 p&p
hand brake £5 + £3.50 p&p
air filter box £5 + £4.50 p&p
set of 4 wheel arches £10 + £11.25 p&p but 2 of them do have cracks in them
engine splash guards £10 £4.50 p&p
alloy wheel nuts and locking whel nuts £10 + £4.50 p&p
battery cable £10 + £4.50 p&p
chrome window strips £10 + £5.00 p&p
throttle pedal £5 + £3.50 p&p
black radio housing £5 +£3.50 p&p
wiper motor bracket and rubber £5 + £3.50 p&p
clear front indicator £4 + £2.00 p&p
spot light x1 £5 + £4.50 p&p
reversing light £5 + £4.50 p&p
n/s headlight £5 + £5.00
headlight resistor £5 + £2.50 p&p
gear gaiter and gear knob £5 + £3.50 p&p
interior mirror £5 + £3.50 p&p
interior door handles levers £5 + £5.00 p&p
rear mud flaps £10 + £4.50 p&p
number plate light £5 + £3.50 p&p
front seat catches £10 + £3.50
Posted 19 April 2011 - 04:02 PM
Posted 19 April 2011 - 05:30 PM
Posted 19 April 2011 - 08:06 PM
Posted 19 April 2011 - 08:13 PM
Edited by 79 clubby, 21 April 2011 - 09:55 PM.
Posted 19 April 2011 - 08:14 PM
Do a deal on the throttle pedal and battery cables?
hi
i will sent you a pm as i no you have asked about a couple of my metro parts.
Posted 19 April 2011 - 08:35 PM
Edited by 79 clubby, 22 April 2011 - 10:30 PM.
Posted 19 April 2011 - 08:37 PM
ta
Mike
Posted 19 April 2011 - 08:46 PM
Edited by 79 clubby, 21 April 2011 - 09:56 PM.
Posted 19 April 2011 - 08:54 PM
Posted 19 April 2011 - 08:55 PM
Posted 20 April 2011 - 06:37 AM
Am interested in the o/s door, what condition is it in and could you send me a pic? Where abouts in Hertfordshire are you for pick up?
Kev
Posted 20 April 2011 - 07:43 AM
Posted 20 April 2011 - 07:30 PM
Hi, do you have the front plastic vent openings both sides that are at the front grille, where the flexible fresh air hoses go in to? One looks like a black 80mm elbow joint on the driver side (part PBM10019 or JKA10012 )and the other is a smaller near triangle shape pasenger side? Cheers
no sorry i don't have these parts as they where broken and the car has now been scraped.
Posted 20 April 2011 - 07:34 PM
