When To Have Crankshaft Re-grind?
10 replies to this topic
#1 Iain L
Iain L
  • 217 posts
Posted 19 April 2011 - 05:31 PM
Hello all. Im going to be rebuilding my 998 soon as its getting a little tired now and with 107k on her most of the gaskets an seals on engine are leaking oil everywhere!
My question is how do you know if the crank will need a re-grind?
The engine still runs well, apart from burning a bit of oil and slight blue smoke bottom end is, or seems very healthy. So will it just be a case of new shells, bearings etc or will you only be able to tell when engine is stripped?
Thanks Iain
#2 Wil_h
Wil_h
  • 3,244 posts
Posted 19 April 2011 - 05:48 PM
You need to measure the journals and see how they compare the the specified limits in the haynes. If they are too small then you'll need a grind.
#3 Iain L
Iain L
  • 217 posts
Posted 19 April 2011 - 06:29 PM
Ok thanks, measure it with some vernier calipers??
#4 Wil_h
Wil_h
  • 3,244 posts
Posted 19 April 2011 - 07:22 PM
Yep that's what I use.
#5 Ethel
  • 26,029 posts
Posted 19 April 2011 - 08:24 PM
What state are the shell bearings in?
#6 Iain L
Iain L
  • 217 posts
Posted 19 April 2011 - 09:15 PM
No idea as of yet, engine is still in car, im just trying to work out what will need to be done.
As said above, bottom end seems very healthy so im not expecting to find many problems when i strip it but i suppose you never know...
#7 Ethel
  • 26,029 posts
Posted 19 April 2011 - 09:52 PM
I'd go by the condition of the shells - it's hard to wear a steel crank without chewing up the tin bearings as well. Measuring accurately with verniers is nigh on impossible, even if the journal is the right thickness between the caliper jaws it doesn't mean it's true & concentric with the rest.
#8 TopCatCustom
TopCatCustom
    Previously known as C4NN0N.
  • 1,134 posts
Posted 20 April 2011 - 07:12 AM
You need to use a micrometer for an accurate reading. If verniers were good enough then machine shops would use them as so much quicker!
#9 MRA
MRA
  • 7,607 posts
Posted 20 April 2011 - 07:28 AM
Verniers have the nickname of very-nears :thumbsup:
You will need to measure the journals for ovality, barrelling, tapering ...... not to mention the surface finish, we use a surtronic surface gauge for the last one.
#10 Iain L
Iain L
  • 217 posts
Posted 20 April 2011 - 04:12 PM
Sounds like it would be best to get a regrind then, being as there not too expensive and ive not got any of the measuring tools etc.
Thanks for info
#11 Big_Adam
Big_Adam
  • 7,435 posts
Posted 20 April 2011 - 04:38 PM
I just gave mine to my machine guy, £10 to check its straight and everything was in spec.
