Hi All,
I need to remove the supercharger pulley in order to align the belt with the crank pulley (actually move it nearer the supercharger as there is about a 5mm gap at present)
Any ideas to how I remove the pulley and how it can be adjusted...?
Thx
Matt
Supercharger Pulley Removal / Adjustment
white Mk11 beast
, Apr 20 2011 06:04 PM
5 replies to this topic
Posted 20 April 2011 - 06:04 PM
Posted 20 April 2011 - 09:45 PM
You'll need a pulley puller- got mine off eBay for a few quid. According to Jonspeed the stock charger pulleys are made from steel and you need to heat them up in the oven to let it expand and then push it on the shaft before it cools. Not tried it myself. I certainly wouldn't have though to align the belt my adjusting the pulley. Surely the manifold design means the pulleys and belt should line up. Have you put a straight edge across the 2 pulleys in situ?
Posted 21 April 2011 - 06:32 AM
The actual problem is that when I run the engine the supercharger belt rides over to the left edge of the pulley and starts scrubbing / self destructing the rubber belt?
I will try and get a straight level to gauge if the supercharger pulley and crank pulley are aligned but with the radiator in place, it's rather tight.
I wonder if it's the tensioner pushing the belt out of alignment?
I'll try and upload a picture over the weekend.
Many thanks for your help.
Matt
Matt
Posted 21 April 2011 - 12:50 PM
i had this same problem,
i sorted it by fitting a VMAX scart tensioner and belt kit!
and surely there should be some gap between pulley and charger unit otherwise it will just rub
Posted 21 April 2011 - 07:18 PM
Thx Blister,
I'll try a new tensioner and belt first as the tensioner may be knackered.
Matt
Matt
Posted 01 May 2011 - 04:28 PM
Hi Guys,
Fitted new tensioner and bracket from Vmax, problem now fixed. If there is any play in your tensioner bearing or the bracket is not dead true, it seems to misguide the belt to the edge of the supercharger pulley and start to shred it.
Thx
Matt
Thx
Matt
