Changing From Pressure Brake Swith To Electronic?
10 replies to this topic
#1 icedaddyuk
icedaddyuk
  • 364 posts
Posted 20 April 2011 - 09:31 PM
Model: Clubman Estate
Year: 1977
I've been having a few issues sealing my brake pressure switch after changing to braided front hoses.
I was thinking of changing from the pressure system to an electric switch.
Is it as simple as changing the union where the switch would be to a three way and wiring in a push the make switch under the brake pedal?
Thanks in advance.
#2 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 20 April 2011 - 09:40 PM
I am not sure about plugging the original switch location. My car's pressure switch failed and I simply left it in place. Then I made a bracket to mount a pedal switch to the pedal box and wired that switch in parallel to the original one.
#3 icedaddyuk
icedaddyuk
  • 364 posts
Posted 20 April 2011 - 09:47 PM
Thanks, I can't get the switch to seal properly hence it's removal and hopefully changing to a different union.
#4 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,147 posts
  • Name: Sean
Posted 20 April 2011 - 10:03 PM
Did you know that the goodridge hoses are handed?
If you've put them on the wrong way round that can lead to sealing issues.
#5 icedaddyuk
icedaddyuk
  • 364 posts
Posted 20 April 2011 - 10:13 PM
I did not know this.
This is probably where I've gone wrong, a 50-50 chance!
The only other issue is that I've rounded off the nut that holds the pressue switch so hopefully I can find a replacement in a motor factors tomorrow morning as unlikely to have one delivered from Minispares etc before Tuesday now.
Thanks for pointing that out!
#6 Shifty
Shifty
  • 13,147 posts
  • Name: Sean
Posted 20 April 2011 - 10:16 PM
Yeah, neither did I!!!
If you look at the hoses one has a deeper thread, this is for the union side.
#7 icedaddyuk
icedaddyuk
  • 364 posts
Posted 20 April 2011 - 10:22 PM
appreciate that, will take a look and swap them tomorrow!
#8 icedaddyuk
icedaddyuk
  • 364 posts
Posted 21 April 2011 - 04:30 PM
Hmmm.... Off to have a look at this now, but have been told from a different source that the hoses aren't side specific.
Anyway, I have everything I need now to change to electric brake switch so will be going with that. Hopefully it's quite simple!
#9 icedaddyuk
icedaddyuk
  • 364 posts
Posted 22 April 2011 - 04:55 PM
Shifty - you were right! the hoses are side specific. There's nothing on the hoses at all the mention this, plus, from the outside they look exactly the same, only the inside is deeper. Fit straight up. Still changing to electric switch though. Seems the more reliable method.
Thanks again for you help.
#10 icedaddyuk
icedaddyuk
  • 364 posts
#11 Shifty
Shifty
  • 13,147 posts
  • Name: Sean
Posted 22 April 2011 - 08:29 PM
I know I was right!!
Made exactly the same mistake myself.
Simon from minispares explained that one side is deeper due to people(like you) having sealing problems.
Standard hoses aren't handed, just the goodridge ones.
