What Have You Used To Fix Your Carpet Set?
Twisty
, Apr 23 2011 06:19 PM
9 replies to this topic
Posted 23 April 2011 - 06:19 PM
Hi guys I have just got myself a new carpet set and was wondering what you have used to fix the carpet in place? so far i have thought of either a tape or spray glue but would like suggestions.
Posted 23 April 2011 - 07:25 PM
Posted 23 April 2011 - 07:46 PM
If the carpet has a decent backing to it, the main front and rear sections shouldn’t need to be glued down, Witch is always handy just in case the mini ever does leak.
But the rest of the carpet sections and any under felt can just be stuck in place with spray glue.
One tip I do have though, if you happen to accidentally get some glue on the carpets while fitting don’t panic. All you need to do is give the area a quick rub over with a rag and some wd40. Sounds odd that using a light oil will remove glue but it does, it also works on oil/grease stains as well.
Posted 24 April 2011 - 07:33 AM
I've just fitted a new carpet set to mine. A newton commercial set. I also used one of their underfelt kits.
I used evo stick carpet adhesive bought from Screwfix, (if you go there don't be tempted by their own no nonsense stuff as it's useless).
I stuck all the underfelt down and also the inner wing, under dash, sill and crossmember carpet pieces. The main front & rear carpet sections are quite a tight fit so I have not needed to fix these at all.
Hope this helps
Good luck
Steve
ps. panel wipe also gets rid of glue overspray.
Hope this helps
Good luck
Steve
Edited by stevede, 24 April 2011 - 09:55 AM.
Posted 24 April 2011 - 07:55 AM
I used to use a combination of gravity and the clips welded to the body to do the job.
Used a bit of spray glue on some bits aswell.
You can use velcro if theres bits you know will be coming back off.
Posted 24 April 2011 - 08:06 AM
After reading Burnards post, reminded me I got some clips with my kit also.
I haven't needed them but I think you can buy the clips on their own. Might be an option for you.
Posted 24 April 2011 - 08:49 AM
Just ordered mine from your link....thanks Shoutforjoy
Posted 24 April 2011 - 08:50 AM
Posted 24 April 2011 - 05:15 PM
Hi guys thanks for the tips and help my carpet set is all fitted now and looks superb. what a difference a carpet makes.
Cheers all
Twisty
Cheers all
Twisty
Posted 07 May 2011 - 12:00 PM
i used a combination of spray adhesive in between the carpet and the sound deadening and velcro to make them removable from the body
