Fan Belt Keeps Turning Itself Upside Down?
Posted 23 April 2011 - 06:50 PM
the pulleys all look to be lined up ok and look/feel fine, and theres no play in any of them, so what could be causing it? just a dodgy batch of belts?
Posted 23 April 2011 - 08:37 PM
Posted 23 April 2011 - 08:40 PM
I ended up splashing out for a new alternator!!
It ran fine with it upside down, but don't leave it longer than you need too!
JK
Posted 23 April 2011 - 09:30 PM
My other silly answer would be that you get some double sided ribbed belts
It really MUST be pulley alignment...........
Posted 23 April 2011 - 09:32 PM
I think someones breaking into your garage and having a laugh with your belt!
Or just fit you new belt upside down to start off with.
Posted 25 April 2011 - 09:51 AM
You may need to swap over to a ribbed type as in cambelt style.
Also look for wear in the bottom of the pulley's signifying tthat the pulley/s are beyond their usefullness.
Edited by mra-minis.co.uk, 25 April 2011 - 09:53 AM.
Posted 25 April 2011 - 10:53 AM
Posted 25 April 2011 - 12:14 PM
He said you had to build them yourself, so he did, and fitted it.
But when ever he turned on the lights, the charging light would come on.
Then he found out it was because it was flipping the belt over.
I've got genuinely no idea of how true this could ever be, and he's got previous for not letting the truth get in the way of a good story. But I found it a good story non the less.
Posted 26 April 2011 - 05:57 PM
Sam what engine revs are you revving your engine to ? if the revs are higher than normal this can happen, also which water pump pulley are you using ?
its a standardish 998, and i see no point revving it higher than 6k as the power feels to drop off, but for normal driving, ive been changing up at around 3.5k. As for water pump pulley, im using the same one that i used on the 1330, with a ribbed/toothed belt.
I swapped over to a motaquip one sunday morning, i had been using halfords ones, and could visually see that the halfords one was a bit thinner on the flat bit (opposite side to the toothed bit), than the motaquip one, anyway, done around 600 miles, mostly motorway, sitting at 70mph, jut under 4k rpm, since then, and its still the right way up, so im pretty sure it were dodgy belts or i picked up the wrong ones, thanks all anyway.
Edited by samsfern, 26 April 2011 - 05:59 PM.
Posted 26 April 2011 - 06:25 PM
http://www.mra-minis...to-look-for.htm
Edited by mra-minis.co.uk, 26 April 2011 - 07:07 PM.
Posted 26 April 2011 - 06:37 PM
Edited by samsfern, 26 April 2011 - 06:39 PM.
Posted 26 April 2011 - 07:10 PM
