Really Low Power/torque On 998?
5 replies to this topic
#1 teamjellybeanmini
teamjellybeanmini
    Starting My Mini Up
  • 3 posts
Posted 24 April 2011 - 12:16 PM
Hi there! I've got a 1989 shell with a 998 from a 1984, The engine has been stage one tuned, recently had a refurbed carb put on it HS4 (with red jet), K&N filter, and a sportex twin box centre exit on it. My main problem is i've got very little torque coming from the engine. Everytime I try to pull away i have to slip the clutch to get it to not stall! it seems ok once its moving but has very little power on the bottom end! I've checked the timing and its all spot on, just don't know if the 'Stage 1' add ons are causing the problems
Can anyone help?? I'm not sure if i've got the correct needle for the carb, its got a AAC in there at the moment (came with the carb) and a red spring.
Any help/ideas would be very much appreciated!
Rich
#2 Tommyboy12
Tommyboy12
  • 2,255 posts
Posted 24 April 2011 - 01:28 PM
Have you actually had the car tuned on a rolling road? Just sticking the needle in and hoping it runs fine is a false hope.
#3 teamjellybeanmini
teamjellybeanmini
    Starting My Mini Up
  • 3 posts
Posted 24 April 2011 - 02:04 PM
No not yet, It's having some front end work done on it at the moment so it can't go anywhere, and i'm not sure of any good classic tuners with rolling road around here. I just wanted to see if there was anything blatently wrong with the set up as is. Does anyone know of any places down south (Sussex) for rolling road set ups?
#4 muzzal 1275
muzzal 1275
  • 131 posts
Posted 24 April 2011 - 02:29 PM
it might be worth having a look at the dashpot oil
mine was over filled once and i had the same problems
#5 cap'n crunch
cap'n crunch
  • 1,060 posts
  • Local Club: .
Posted 25 April 2011 - 09:46 AM
http://geralddale.co.uk/
#6 bmcecosse
bmcecosse
  • 9,699 posts
Posted 25 April 2011 - 10:08 AM
Make sure the vacuum advance in the dizzy is connected - and working as it should. You really shouldn't need to spend a fortune on a Rolling Road set-up for such a simple modification.
