Driver Door Dropped ?
4 replies to this topic
#1 Lewis-142
Lewis-142
  • 146 posts
  • Local Club: BMC
Posted 24 April 2011 - 10:48 PM
Drivers door has dropped making it hard to shut you have to lift up a pain whats gone or what will fix it back in line do i need new parts and how hard is it to do ????
Lewis
#2 charie t
charie t
  • 3,153 posts
Posted 24 April 2011 - 11:09 PM
Sounds like your hinge has worn or snapped the pin. New hinges and apply a dab of oil every service.
Worst case there's plenty of corrosion and its broken through.
#3 MiniLandy
MiniLandy
  • 796 posts
  • Local Club: HAMOC
Posted 24 April 2011 - 11:11 PM
Top door hinge, mine's gone too.
Take the front driver's side wheel off, and look at the door hinge nuts. It could be a simple case of loosened nuts, oooor a full blown case of the panel that the door bolts to being rotten away.
Take the wheel off, and have a look :D
#4 charie t
charie t
  • 3,153 posts
Posted 24 April 2011 - 11:26 PM
Either or both of the hinges can be worn. its not just the top thats definately gone
Opening the door and inspecting the hinges and the area around where they are mounted will be suffice.
#5 Lewis-142
Lewis-142
  • 146 posts
  • Local Club: BMC
Posted 25 April 2011 - 12:31 AM
ok wheel off tomorrow see whats hapening thanks ill report my findings
