Which Dashpot Oil?
16 replies to this topic
#1 thebullet
thebullet
  • 1,337 posts
Posted 25 April 2011 - 12:24 PM
Hi all, I have a 998cc Sprite with a Cooper head and Single HS4 carb.
I had it recently set up on the rollers and when I was at southam they put in what seems to be thinner Dashpot oil, the car is fine but has a flatspot still.
It is now run leaner because the timing has been set up correctly. I wanted to know why it still has this flatspot and had a thought that it could be the thinner dashpot oil that was put in? My car itself has a thicker oil in it.
I think they put 20W 50 oil in it.
Would it give it a flat spot under heavyish acceleration?
And with the cooper head what would the best dashpot oil be? thicker?
Thanks for the help.
Matthew.
#2 bmcecosse
bmcecosse
  • 9,699 posts
Posted 25 April 2011 - 02:04 PM
I use 3 in 1 - the thinner the better to get the piston to lift and let the air in! May have to set it richer though. It's not hard to try different oils - till you get something you like.
#3 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 25 April 2011 - 02:07 PM
yer i always say, try the oil that makes the engine run the best, personally in my cars i use the engine oil (20w50)
What I will say is DON'T do what a previous owner did, and use lemon juice, I kid you not!
#4 thebullet
thebullet
  • 1,337 posts
Ok thanks, I did think this, but I didn't want to change something after I had spent all that money on getting it tuned! I may put some thicker stuff in it again and see what that does.
Thanks,
Matthew
#5 thebullet
thebullet
  • 1,337 posts
Posted 25 April 2011 - 02:10 PM
Well according to Mini and metro in southam my engine oil is too thick, but it is what the Haynes Manual says to put in it.
Like I said I may try putting thicker stuff in it again that is in the engine, probably help the flatspot a little!
Matthew\
#6 MRA
MRA
  • 7,607 posts
Posted 25 April 2011 - 02:20 PM
The correct grade of oil for the SU carburettors is a single grade not a multigrade such as 20/50....
SU oil is available if required..
#7 thebullet
thebullet
  • 1,337 posts
Posted 25 April 2011 - 02:29 PM
Ok thanks,
http://www.minispare...ty=pb&pid=37250
By putting something like that in, would I notice much difference to the 20/50 that is in it now!
thanks.
#8 liirge
liirge
  • 4,097 posts
Posted 25 April 2011 - 03:49 PM
its interesting this, I 100% agree with you..
however as a point using multigrade oil surely acts a bit like a choke? as it will be thicker when the car is cold, thus richening the acceleration mixture, and as it gets warm the oil gets thinner and this weakens the mixture a wee bit.
I've been pondering this novel musing of mine for a while, what do make of that little idea?
#9 thebullet
thebullet
  • 1,337 posts
Posted 25 April 2011 - 03:56 PM
My flat spot seems to go away mostly when it is warm, I was hoping it was going to be the other way round, meaning I need thicker oil back in it.
#10 J960mayfair
J960mayfair
  • 267 posts
Posted 25 April 2011 - 04:05 PM
i use 2 stroke motorcycle engine works a treat :)
#11 liirge
liirge
  • 4,097 posts
Posted 25 April 2011 - 04:06 PM
surely you would need thinner oil if it goes away when warm...
#12 thebullet
thebullet
  • 1,337 posts
Posted 25 April 2011 - 04:07 PM
That's what i mean :) haha
Yeah so, maybe I should go straight for this single grade? which isn't thick when cold?
#13 liirge
liirge
  • 4,097 posts
Posted 25 April 2011 - 06:10 PM
Yeah 3 in 1 is pretty thin and popular on here!
#14 thebullet
thebullet
  • 1,337 posts
Posted 25 April 2011 - 06:16 PM
Thanks for the help. I think I will try the 20w40 that is in the car atm. See what happens! I'm sure it changes as I have a different head on it.
#15 minotaur
minotaur
  • 39 posts
Posted 25 April 2011 - 07:25 PM
The original oil supplied by SU is SAE20 , 3 in 1 oil is SAE20
