Monster Moped
3 replies to this topic
#1 PAINTPOT
PAINTPOT
  • 47 posts
Posted 25 April 2011 - 01:13 PM
my next door neighbour bought his son a pink moped .He ask if i could do any thing with it .So i give it a quick little paint job.
Attached File  Photo0081.jpg   78.77K   13 downloads
Attached File  Photo0088.jpg   37.61K   11 downloads
Attached File  Photo0090.jpg   78.74K   25 downloads
Attached File  Photo0091.jpg   94.01K   24 downloads
Attached File  Photo0092.jpg   85.7K   19 downloads
Attached File  Photo0093.jpg   90.62K   15 downloads
Attached File  Photo0094.jpg   87.13K   20 downloads
Edited by PAINTPOT, 25 April 2011 - 01:32 PM.
#2 charie t
charie t
  • 3,153 posts
Posted 26 April 2011 - 09:19 AM
wow thats quite a transformation! nice work paintpot ;D
Is the green through the black a trade trick or is it quite simple?
#3 ajperry
ajperry
  • 316 posts
  • Local Club: Thames Valley Mini Club
Posted 26 April 2011 - 09:35 PM
thats brilliant! whats the paint style called? marbling? i too would like to know how its done, i'm intrigued!
#4 PAINTPOT
PAINTPOT
  • 47 posts
Posted 27 April 2011 - 10:59 AM
first of all you put a solid color on green or a different color if preferred.Flat your color with grey scotch or 1200 w/d .Then i put one full wet coat of water based black base on.While it was still wet i dabbed of the black with a scrunched up plastic bag to get the effect.Water Based stays wet so its easy to do.Then i clear coat it .Flat the clear coat then re clearcoated it. If you do not have water base ,you can use solvent black base.You will have to do this a different way.Mix your black that has been thinned .Dab you scrunched up plastic in the paint,Then dab on accordingly how much effect you want ,then clear coat.This door was done with water base
Edited by PAINTPOT, 27 April 2011 - 11:00 AM.
