Window Tint
10 replies to this topic
#1 ghostleader101
ghostleader101
  • 95 posts
  • Local Club: N/A
Posted 26 April 2011 - 07:18 AM
ive got a Mini Neon in nordic blue (greyish/blue) and have bought some blue window tint and im wondering which way is better to apply it, on the outside of the car or the inside?
And when putting it on the Heated Rear Window how do you do it so when you put the heater strips on the tint doesnt come off? did that make sence? :S :L
Rob Cool :thumbsup:
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 26 April 2011 - 07:54 AM
Inside, and don't forget you can't put it on the windscreen or either of the front windows, so rear quarters and back window only.
#3 sparky26
sparky26
  • 38 posts
  • Local Club: Mini Club of Ireland
Posted 26 April 2011 - 08:22 AM
Agreed its only the rear section of the car that you can tint if you do the front the coppers will pull you over make you pull a large piece of it off each window (so they know when you go home you will take the rest off) and then fine you for having it.
Trust me seen it happen
#4 minisam92
minisam92
    Banned from Classifieds Due to Selling of Weapons After Warning
  • 1,026 posts
Posted 26 April 2011 - 11:38 AM
rear 3 can be up to 100 % tinted front 2 can be up to 35 %
#5 ghostleader101
ghostleader101
  • 95 posts
  • Local Club: N/A
Posted 26 April 2011 - 12:20 PM
been doing it for nearlly an hour, measuring it all out and i comne to do it, omg its so hard, looks really bad ;D bubbles lines everywhere :) will have to get it done professionally i think, unless anyone has any ideas how to do it easily :L
thanks for the info :)
Rob :)
#6 minisam92
minisam92
  • 1,026 posts
Posted 26 April 2011 - 12:31 PM
Rob :)
when i tired to spray tint had the windows out of the car
cleaned them then sprayed them really light left it for half a day sprayed again and turned out not to bad
but did u get instructions ?
#7 screech
screech
  • 3,136 posts
  • Local Club: Bognor rock ya mini & WSMOC
Posted 26 April 2011 - 10:22 PM
Its not a simple job to do. Does take a lot of practice.
Iv done all of mine myself, everyday cars as well as my mini, although had the rear screen done the first time as i couldnt do it, but iv now got the nack and im happy iv just done my first rear screen.
Rear sides are the easiest as they are flat.
Are you removing the windows to do them?
You will also find the quality of the film helps. The cheap 'halfords' stuff is really thin and scratches/peels easily, and i doubt it will form the rear screen curve very well at all.
#8 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 27 April 2011 - 05:39 AM
The front windows and windscreen on post '85 cars must allow a minimum of 75% of light through.... pre '85 it is 70%.
#9 89mini-boy
89mini-boy
  • 486 posts
  • Local Club: OXMOC
Posted 27 April 2011 - 05:51 AM
thats what i thought, but the others(guess-works.com and sparky 26) were saying front cant be tinted i have a mayfair with the original glass and all my windows are tinted blue like when it came out of the factory
#10 olds_kool_lews
olds_kool_lews
  • 3,602 posts
Posted 27 April 2011 - 07:37 AM
a good way to get it flat without air bubbles and creases etc is to mix up a solution of washing up liquid and water in a squirty bottle, remove the windows and religiously clean them, wash them, wipe them over, use a stanley blade like a scrapper and run it over the window to remove any specs of dust and debris that have really stuck into the window.
this is for the rear sides and door windows -
using the spray bottle, give the window a good soaking on the inside surface, keeping the window flat and level, then comes the tint, cut the tint 2" oversize for the window, then peel the backing film off the tint about 2" (it becomes very static and tends to cling together if you try to remove it all at once, especially the cheap stuff!) get a couple of clothes pegs and peg the tint to the front flat edge of the window with the backing film between the window and the tint, then using both hands, pull the backing film towards you slowly until its removed compeletly, once removed, the water/washing up liquid acts as a barrier and stops the tint from sticking, using the squeegy supplied withe the kit, start from the middle and do a st georges cross on the tint, so your left with 4 sections, 1 by 1, work the water out with the squeegy and you should be left with a nice flatbubble free tinted window! allow any remaining water to evaporate/dry out between the glass and tint before trimming the excess tint off, or you'll risk tearin/moving the tint.
i did my van rear windows like this and thhey came out really well! ive not attempted a curved window before, but ive heard people cutting the tint into strips and using the heating elements on the rear screen to hide the joins! hope this helps at all :wub:
Edited by olds_kool_lews, 27 April 2011 - 07:40 AM.
#11 minisam92
minisam92
  • 1,026 posts
Posted 27 April 2011 - 09:49 AM
must be 25% front i heard then lol
