Easiest Way To Fit Windscreen
Posted 26 April 2011 - 02:08 PM
Could someone post an easy way to replace the windscreen, any tips and tricks would be most helpful.
pothole
Posted 26 April 2011 - 02:12 PM
but if thats not an option then the right tool, water and washing up liquid play a big part
Posted 26 April 2011 - 03:00 PM
Posted 26 April 2011 - 03:14 PM
Posted 26 April 2011 - 03:43 PM
Posted 26 April 2011 - 04:09 PM
i found the easiest way was to let a 8 and 1/2 month pregnant woman fit it for you
I only have 10 days for a retest, cant wait 8 and 1/2 months for the missus.
Posted 26 April 2011 - 04:20 PM
http://www.theminifo...showtopic=10693
I have done a couple of glass installations recently and have found that "personal lubricant" from the family planning section of your pharmacy is a great lubricant to aid glass installation.
Posted 26 April 2011 - 04:23 PM
doesnt have to be your missus.. any pregnant lady whos up for it should do. im sure thas a directory somewhere for " pregnant and up for it".. that should helpi found the easiest way was to let a 8 and 1/2 month pregnant woman fit it for you
.. i think.
Edited by minilester, 26 April 2011 - 04:23 PM.
Posted 26 April 2011 - 05:12 PM
.. i think.
yes that's right
i borrowed a mates wife and only had to pay her in cake
Posted 26 April 2011 - 06:30 PM
one of the recent mini mags does an article on this i was reading online the other night, pictures with a step by step guide, you can preview the mag online and it allows you 3 'zooms' to read for free, maybe someone on here read it and can tell you which issue?, i remember them using wd40 to fit, it did make it look simple, but i'd deffo use a new sealdoesnt have to be your missus.. any pregnant lady whos up for it should do. im sure thas a directory somewhere for " pregnant and up for it".. that should helpi found the easiest way was to let a 8 and 1/2 month pregnant woman fit it for you
.. i think.
yes that's right
Posted 26 April 2011 - 06:36 PM
pothole
Posted 26 April 2011 - 07:23 PM
Fit seal to the frame first.
I used spray window cleaner as a lube worked a treat.
Put screen into bottom of seal as much as you can get in, then like mentioned above go round with a screw driver carefully and peel the seal over the glass.
As you peel keep tapping the screen down towards the frame locates the screen in the rubber. For most of the it will just be a case of pushing gently with the screw driver in the groove this will lift the rubber over the glass.
Don't go mad you'll chip the glass
Warm the sealer strip up in hot water first makes it more flexible.
The sealer strip get the correct fitting tool its essential. Push strip through the loop of the tool, Push end of strip into groove in the seal then go round with the tool in the groove, it will spread the rubber and you can use your non tool hand to press the strip into the groove.
Use plenty of your chosen lube.
Two methods work well with the tool, the slow steady push or the wiggle
oh it can be tiring on the arms
you can get the fillet tool with a roller which pushes the strip into the groove, probably the better tool, but mines just the diamond shaped loop type no roller
Edited by lrostoke, 26 April 2011 - 07:25 PM.
