when i brake in my mini the front brakes feel a little lumpy! its hard to explain but they just feel un-smooth (if thats even a word?)
do all minis feel like this or do i have yet another problem with my brakes?
lumpy braking
davexdavexdave
, Jan 11 2006 12:30 AM
4 replies to this topic
Posted 11 January 2006 - 12:30 AM
Posted 11 January 2006 - 07:27 AM
If you've got disc brakes on the front (post 84 usually) then it could be warped discs. That would give an odd feeling through the pedal.
Posted 11 January 2006 - 07:35 AM
also check that the bolts that hold the disc in place are tourqued up properly!if a couple have come loose then that could cause this too!
Posted 11 January 2006 - 11:40 AM
i have had this problem before as mmc said it is probally warped discs mine where. just replace the discs and pads and you should be fine.
Posted 11 January 2006 - 06:39 PM
much thanks
