what water temp would you expect a tuned mini to run at ? :erm:
water temp
stag
, Jan 11 2006 12:37 AM
5 replies to this topic
Posted 11 January 2006 - 12:37 AM
Posted 11 January 2006 - 07:35 AM
Normal... :cheese:
However, if you want the best out of your engine, you want the water temp to be no more than 60 degrees, which is 30 degrees less than normal.
Posted 11 January 2006 - 07:37 AM
mine has a stage 1 1275 and it runs quite cool.
about half way between the blue bit and half way.
Think it has a different thermostat in to normal though
Posted 11 January 2006 - 01:47 PM
Mine runs halfway between the blue and the halfway mark now its winter, but in the summer it runs below halfway in normal driving and traffic, but goes up above halfway when going about 80 on the motorway.
Posted 11 January 2006 - 05:12 PM
I think my temperature sensor is buggered. Mine never leaves the blue bit at the bottom. And yes, the coolant is full...
Posted 11 January 2006 - 05:19 PM
mines a 998 and warm it up to 60 and start and finish it is 110 :nugget:
