Rear Knock/crash When Going Over Bumps
2 replies to this topic
#1 DMC
DMC
  • 108 posts
Posted 29 April 2011 - 11:27 PM
Hello all,
I am experiencing a sharp knock/crash sound when going over small bumps and holes in the road. It seems to be coming from the back right side. I jacked my mini up and checked that the wheel did not have any play in it side to side and up/down. I also pushed up and down on the back of my mini and i did hear a little bit of what I am hearing from inside the car. The problem is I have stripped the interior of the car, no back seats, etc. so every noise is magnified now!
I was thinking about trying the bushes on top of the rear dampers/absorbers first.
Could the rear knuckles cause this noise? are there any areas I should look at besides the absorbers?
I did a visual and also checked nothing was loose anywhere. I also greased up the rear suspension nipples.
Any advice is greatly appreciated!
Dave
#2 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 30 April 2011 - 01:50 AM
are the radius arm bushes shot?? do you have standard suspension, neg camber could be knocking the wheel against the shock??
unlikely bu loose wheel nuts/.. my sister drove her car for a good 100 mile with "a funny knocking noise", turned out to be 3 loose wheel nuts and a snapped stud!!
#3 danrock101
danrock101
  • 2,478 posts
Posted 30 April 2011 - 02:21 AM
tried the battery? :)
