Spi Immobiliser Help
9 replies to this topic
#1 mr tibbs
mr tibbs
    Just On Tickover
  • 6 posts
Posted 30 April 2011 - 03:31 PM
Hi all !
just put my carb pick up in for paint (at last ) only to be handed my niece's broken into spi .
here's my problem ,I dont do injection > (time to learn )
have changed ignition barrel and locks ,all ok.
but due to loss of immobiliser fob i cant get anyting past clicking of relay's / petrol pump ? HELP!!!
Have lights horn indicators washer spray no wipers !!
now from reading your posts I feel I need to get a new fob and ecu ( behind dash ) ?
would I be correct? if so where from??
any response would be appreciated or if anyone knows of a person or garage in the Ashford, middx /heathrow area
I would be greatful.
Hope to have pick's of pick up soon to add .cant wait !!!!!!!!
Thank's Tibbs
#2 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 30 April 2011 - 03:46 PM
To do it properly, you really need a full kit - ie key fob + Alarm ECU (mounts behind the dash) + Engine ECU - under the bonnet - both ECUs are coded together on certain models.
Or, you could try this - have had no experience with it. Do not know if it works
check your unit behind the dash, this only works with alarm ECUs numbered: YWC104040
#3 mr tibbs
mr tibbs
    Just On Tickover
  • 6 posts
Posted 30 April 2011 - 03:55 PM
hi ! ecu reads ywc104540 so should i not try ?
where might i get the fobs and ecu's ?
thanks for reply
#4 Spiffingly Good
Spiffingly Good
  • 441 posts
Posted 30 April 2011 - 07:56 PM
I've not used these or endorse them, and you may be able to find cheaper, but a quick search revealed this Keyfobs Some useful info on there.
#5 Guest_minidizzy_*
Guest_minidizzy_*
  • Guests
Posted 01 May 2011 - 12:08 AM
If I understand correctly all you need to do is replace the fob. Replacing the immobiliser ecu and engine ecu seems very over the top and they are probably not easily obtainable anyway. Look at
http://www.remotekey...ver/rover-mini/
If it is the two button type you send them the immobiliser ecu (not the engine ecu) and they can provide a new programmed fob very quickly. I am not sure how it works for the earlier single button type but I am sure they can explain.
I have used them to refurbish a fob so I can recommend them.
#6 elguapo
elguapo
  • 109 posts
Posted 19 December 2013 - 01:15 PM
Sorry for the bounce but need some real help! (is there any other kind??)
My car wont start/prime the fuel pump. I have replaced the relay pack with a brand new one but nothing. I have had the car 3 years and had no key fobs but behind the dash is some black box with an ariel type connector which I presume is related to the alarm system?
Would the car ever have started without the fob?! The car is a 1994 SPi Cooper is there an easy way to bypass or test?
Michael
#7 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 20 December 2013 - 10:18 PM
What is the ECU part number MNE101070 or MNE101170? The latter requires the ECU, alarm and fobs to be matched. The alarm sends a code to the ECU to ECU and if it is the correct one, the engine starts and runs. If no code is sent from the alarm or if the code does not match the ECU code, the engine will not start.
The MNE101070 is not coded. It can be used with no alarm or if it has an alarm, the only thing disabled is the starter. You should be able to bump start the car.
#8 MiniMarine
MiniMarine
  • 12 posts
Posted 02 January 2014 - 11:59 PM
I'm having some issues with my immobilizer too. its acting like its not getting power (no LED light).  My ECU is MNE 101150... does that mean i could bumb start? or not?
#9 FlyingScot
FlyingScot
  • 2,664 posts
Posted 03 January 2014 - 07:38 AM
The presence of a number 1 in the sequence after 101 means that it has an immobiliser unit preventing fuel pump operation.
That is
1010XX = no immobiliser originally fitted
1011XX = immobiliser originally fitted
XX = 70 that is Cooper spec as per xrocketengineer's post
XX = 50 standard SPi spec
FS
Edited by FlyingScot, 03 January 2014 - 07:41 AM.
#10 elguapo
elguapo
  • 109 posts
Posted 19 March 2014 - 09:00 AM
guys thanks for the help. Had forgotten about this post. The problem, even after fitting a new relay pack (it needed one) was actually a burnt pin inside the connector to the relay pack. Autospark rewired it and car started straight away. Essentially the relay pack was not getting the trigger to prime the system
