1974 Austin Mini Wont Go Into Gear! Help Needed!
Posted 02 May 2011 - 03:30 PM
The car goes into gear smoothly when the engine is OFF, however when the car is on, the gears are very difficult to get into, particularly first gear. I understand that she can get the car into gear when pressing the clutch VERY hard, sometimes its worse than others & she has no idea what its up to.
Any help ASAP on this matter would be greatly appriciated.
Regards
Stacey x
Posted 02 May 2011 - 03:51 PM
some basics to start on
Posted 02 May 2011 - 03:55 PM
But the fault you describe certainly sounds like a clutch disengagement issue.....
So check all of the linkage from the clutch master cylinder forward....
Posted 02 May 2011 - 04:17 PM
http://www.mra-minis...h-mechanism.htm
Posted 02 May 2011 - 06:03 PM
Would be great if you could link to the specific parts in the shop once the offending object is found , so if its the hose from the slave to the master cylinder then a link to the correct array or avalible pipes etc .
Posted 03 May 2011 - 08:29 AM
Posted 03 May 2011 - 10:59 AM
nice write up there on your website , a good step of processes to follow !
Is that better ?
http://www.mra-minis...r-diagnoses.htm
Posted 03 May 2011 - 01:18 PM
Posted 03 May 2011 - 03:37 PM
Is that better ?
very sexy mra
Posted 03 May 2011 - 05:18 PM
Hopefully it's the website that's sexy........
