Hey there i got a 1993 mini mayfair. The two clock dash instruments are not working, this includes the lights, petrol and temp gauge, both warning and oil lights. I read up that if the red warning light doesnt work then the car struggles to charge (unsure if this is correct) however with this instruments not working has had an effect on my car charging very strangle lol. I cleaned n changed the fuses on the fuse box and checked the fuses near the dash they all seem fine. What should i change for the dash to work. really need help.
Thanks Scott.
Dash Not Working
Tayzore
, May 03 2011 05:50 PM
6 replies to this topic
Posted 03 May 2011 - 05:50 PM
Posted 03 May 2011 - 05:55 PM
you will need to remove the clocks and check the printed circuit board on the back, these are prone to failure but not usually absolutely everything packs up though.
Posted 03 May 2011 - 06:02 PM
Hey mate had a check over cant see anything wrong with it, its only just stopped working. Could it be the relays maybe?you will need to remove the clocks and check the printed circuit board on the back, these are prone to failure but not usually absolutely everything packs up though.
Posted 03 May 2011 - 07:31 PM
Have you checked to see that the large mutli plug connector on the back of the speedo cluster is connected and engaged fully, that would be the obvious culprit if nothing at all is working.
Posted 03 May 2011 - 09:49 PM
Yea Ive triple checked that mate. Ive got the dash lights to come on and the blue full beam light to work, its just the rest its so strange lol, def think its messing with the charging system, anyone got any more ideas?
Posted 06 May 2011 - 07:59 AM
Any ideas anyone? really need some help.
Posted 18 June 2011 - 04:56 PM
hey, any luck tayzmore? i have the same problem with a 1993 sprite, i've checked the fuses, the earth and the plug and their all fine. did u get yours fixed?
