Mini 1.5 Vtec Conversion
Posted 03 May 2011 - 07:47 PM
how would i set them up to find out
I have cut the shafts allowing extra to be cut off when i find out the length i need to make them i have sleeves made and am just waiting to find this info out.
Posted 03 May 2011 - 08:07 PM
Posted 03 May 2011 - 08:14 PM
It mightbe me but i dont understand what your sayinghi mate. i measured from the inside of the pot joint to the outer face of the outer cv joint, then from the outside of the pot joint to the outside of the outer cv joint, added them together and then divided by two to get the length to the middle of the pot joint, and then added the length of the splines that go in to the outer cv. i hope this helps. i been doing mine for just over a year now and nearly finished. i have a 1.5 vtec aswell
Posted 03 May 2011 - 08:21 PM
I think i know what you mean now so you end up with i/2 the distance in each pot with wheels pointing forward
Posted 04 May 2011 - 09:38 AM
Posted 04 May 2011 - 03:06 PM
Does anyone know how to find this measurement i have searched and come up with nothing
you need to do it on your car as every one varies. and yes it comes out with inner cv joints half way in with wheels straight ahead
Posted 05 May 2011 - 03:45 PM
[/quote]
Well is this dangerouse i would of thought the only way to get them out would be to remove the front hub and then dismantle
